They tried to jack my car! Couple questions on ignition switch wires.
Old Nov 19, 2007 | 08:31 AM
aalouie's Avatar
Default They tried to jack my car! Couple questions on ignition switch wires.
Ok so last night i had a feeling that if i didnt lock my doors somethin bad was gonna happen so i told my brother to do it for me (not sure if he did or not) but this is what i found this morning along with my stereo being jacked
the car
the carnage
the cracked ignition switch
I figured out most of the wires but does anyone know what the blue white and white red are? I might have more questions if i cant figure out how to wire it all up.
Old Nov 19, 2007 | 08:43 AM
dem0nk1d's Avatar
what the hell. i would have just take out the two screws and turned the **** over. these jacker's must have been on crystal meth. I'd just say go down to your local junkyard and pickup a new ign switch. Why do you have fuses pulled. Looks like a huge 50A for the battery and maybe ECU.
Hey better news is you still have a car. Start look into installing a alarm and whatever else will help out. everything little thing helps. They could be back.
Old Nov 19, 2007 | 08:45 AM
dem0nk1d's Avatar
show me a picture of the steering rack as well. you might need to pick up a new rack as well, some times the **** gets bent like no other. You'll have a crooked steering wheel.
Old Nov 19, 2007 | 08:48 AM
BJA86's Avatar
Default Re: They tried to jack my car! Couple questions on ignition switch wires. (aalouie)
what a mess dumb thieves,seriously like he said get some security on that rex alarm,kill switches,ect you got lucky this time next time you will be left with a parking space.
Old Nov 19, 2007 | 09:01 AM
aalouie's Avatar
Default Re: They tried to jack my car! Couple questions on ignition switch wires. (BJA86)
They stole my bothers 240sx with a bump key 2 weeks ago found it a block away but the main problem i think is not locking the doors i have a ford probe with shaved handles nobody ever tried messin with that thing and its been parked for months. I was gonna shave handles on my crx but i often close the door and forget the keys inside. The fuses are blown interior and igniton fuse. I actualy have an alarm but the remote that i have doesnt work for some reason and the one that does is at my gurl friends go figure, im also going to add a fuel pump kill. I want to put switches for the accessory 1 and 2 and i have a key fob sensor that im going to use for the starter signal kinda like the push button s2000 mod
Steering Columb.
Old Nov 19, 2007 | 09:09 AM
I CRX I's Avatar
AND JUST A REMINDER, ITS PROBABLY NOT A GOOD IDEA POSTING YOU LICENSE PLATE UP EITHER. SORRY FOR CAPS
Old Nov 19, 2007 | 09:49 AM
aalouie's Avatar
Default Re: (I CRX I)
Ok figured out all the wires, the blue and white is a ground. Should i just ditch it, when hooking up the switches?
Jagan'92
Feb 20, 2007 04:54 PM
SickWitIt2.0
Jan 22, 2005 11:27 AM
Magick211
May 21, 2003 03:23 AM
Ausmith
Jan 15, 2003 10:55 AM
