HELP! Emissions went from bad to worse!!
Old Nov 19, 2007 | 08:21 AM
Uncle Willie's Avatar
Default HELP! Emissions went from bad to worse!!
I also posted this in the integra section.
After failing the first time i took the car in (it registered 1.67 g/mi of HC, 10.51 g/mi CO, and 3.71 g/mi of NOx) i change the spark plugs, wires, dist cap and rotor, and O2 sensor. I also reset the ecu. Now i just took it in and it did WAY worse. Its now running 5.87 g/mi of HC, 36.95 g/mi of CO, and 16.855 g/mi of NOx.
What the hell is going on? What could be causing it to run so rich?
Old Nov 20, 2007 | 09:58 AM
Default Re: HELP! Emissions went from bad to worse!! (Uncle Willie)
BUMP.
I have a smsp high flow cat on it that i bought in spring and it only has about 2k on it. Im thinking i should just throw the hole stock exhaust back on.
Old Nov 20, 2007 | 03:11 PM
Mikey3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Uncle Willie &raquo;</TD></TR><TR><TD CLASS="quote">BUMP.
I have a smsp high flow cat on it that i bought in spring and it only has about 2k on it. Im thinking i should just throw the hole stock exhaust back on. </TD></TR></TABLE>
yeah that would prolly be a good start. was the car warmed up?
Old Nov 21, 2007 | 08:45 AM
Default Re: HELP! Emissions went from bad to worse!! (Mikey3000)
Yah, it was running for a good 20-25 minutes before it got tested, then ran for another 15-20 minutes on their tester.
Uncle Willie
Nov 21, 2007 02:17 PM
Jameson
Mar 29, 2006 07:57 AM
urbansi
May 9, 2005 08:51 AM
DriveSideWays
Aug 26, 2004 04:00 PM
civic596
Honda S2000
20
Jan 22, 2004 09:32 PM
