HELP ME REFINISH MY ENKEI 92's......
well i got me a set of enkei 92's 16x7 with a 0 offset....i would like to know where can i get them gold chrome polsihed if not can some of you give me some suggestions or help on restoring them.... thank you....
they are going on my dc2.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BXk24ek9 »</TD></TR><TR><TD CLASS="quote">lol yeah i know but ive got good info so i think i should be able to fit them in....</TD></TR></TABLE>
i don't think you will make it.
as far as your original topic, i searched for you and came up with nothing. good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BXk24ek9 »</TD></TR><TR><TD CLASS="quote">sorry for the wack pictures but ill get some better ones soon......
Umm yea that should look sweet heres some inspiration for you!!!!
</TD></TR></TABLE>Umm yea that should look sweet heres some inspiration for you!!!!
They'll fit albeit not easily. Full fender roll/maybe a bit of pull, stretched tires, and mad negative camber. Of course you probably already knew that if you bought 0 offset rims
Good luck!
. Good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hon da top »</TD></TR><TR><TD CLASS="quote">i'd keep the wheels you have on it
Back to his original question....
You can have the wheels refinished at Wheel Collision Center in Bath, Pa.
Wheel Collision Center....click
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1989CivicSi »</TD></TR><TR><TD CLASS="quote">They'll fit albeit not easily. Full fender roll/maybe a bit of pull, stretched tires, and mad negative camber. Of course you probably already knew that if you bought 0 offset rims
Good luck! </TD></TR></TABLE>
I agree, it just may require A LOT of work to make it happen and even then you may still rub or even if you don't its questionable how well the car will handle.
Don't get me wrong I am VW fanatic and love the look wide low offset wheels with stretched tires but its questionable if the cool look is worth all the work when usually your worsening the handling capabilities of the car.
I myself am trying to decide whether to go with a wider lower offset wheel or a something with a slightly higher higher offset that will allow me to put more rubber on the ground.
. Good luck! </TD></TR></TABLE>
