JDM civic fuse question... need some input.
Ok i have a 93 JDM EG6 sir and somehow i blew fuse 24/25 the fuse for the VSS odometer and whatnot. but here is the problem on the under dash fuse block where it soposed to have fuse 24 and 25 it just blank. any ideas where i would find this missin fuse?
because we tested the Power for the VSS sensort and it only had .2 volts when it was soposed to be 12v.
When you say the fuse block is "blank" at 24/25, what do you mean? Do you mean it's an empty socket or do you mean there's no metal in there to conduct electricity or do you mean there's no socket there at all?
