Has spark but wont start.
Old Nov 19, 2007 | 06:26 AM
allmotor2.1's Avatar
Default Has spark but wont start.
My car has spark,the fuel pumps comes on but it wont fire.when i turn the key to postion 3 the fuel gauge go,s to 40 then comes right back down to 0 what is the problem
Old Nov 23, 2007 | 11:27 AM
1SiC 3DR's Avatar
Default Re: Has spark but wont start. (allmotor2.1)
sounds like your loosing fuel pressure, maybe check for a fuel leak, or main fuel relay operation
Old Nov 23, 2007 | 01:02 PM
Under_Pressure's Avatar
Default Re: Has spark but wont start. (1SiC 3DR)
could be a bad fuel pump causing fuel to go back or u have a leak.. A bad main relay would not turn on the pump from the begining but shut it off when it warms up...
Old Nov 24, 2007 | 04:52 AM
1SiC 3DR's Avatar
Default Re: Has spark but wont start. (Under_Pressure)
not entirely true older 4th gens when relay goes bad sometimes could turn the pump on and as soon as its builds enough heat inside the relay it shuts it down, older accords are the same way
PatrickFrantz
Aug 21, 2008 05:53 AM
Si-Samuri
29
Jun 19, 2008 05:48 PM
uszcrx
24
Sep 9, 2006 01:05 PM
whitehf
Aug 6, 2006 01:22 PM
ROK801
Oct 31, 2005 07:28 AM
