Will D15B8 cams work in the D15B7?
Someone asked me that question but I wasn't sure of the answer. They are both D series so in theory (and reality) most series engine's cams are interchangeble unless they have quite a bit of difference. Considering th B8 only has 8 valves and the B7 16 valves will swapping the cams work vice versa?(D15B7 cams in D15B8 and D15B8 cams in D15B7?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">no.
B8 cam into B7 = only 1/2 the valves would open.</TD></TR></TABLE>
So maybe you can swap a B7 cam in and open up 8 extra imaginary valves on a B8?
Good to see you Mista Bone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">
Well, due to only working 1/2 the valves, the B8 has bigger lobes. I've always wanted to have the B8 profile on a D16A6 cam just to see. Might be a job for Web
</TD></TR></TABLE>Well, due to only working 1/2 the valves, the B8 has bigger lobes. I've always wanted to have the B8 profile on a D16A6 cam just to see. Might be a job for Web
Sl0wEK
Jan 15, 2007 08:53 AM
216.226.142.95:27016
Jun 28, 2003 01:41 AM
