Idle screw
Old Nov 18, 2007 | 11:36 PM
924doorEG's Avatar
Default Idle screw
Is the idle screw on the throttle body suppose to be all the way tight? or some what loose? i just put a new throttle body on and i dont know where to adjust the screw...any ideas?
Old Nov 19, 2007 | 12:01 AM
924doorEG's Avatar
bump.....help plse
Old Nov 19, 2007 | 04:34 AM
rleonekc's Avatar
Default Re: (924doorEG)
You just put a new throttle body on, are you having a high idle problem?
Old Nov 19, 2007 | 08:15 AM
tpr's Avatar
tpr
Default Re: Idle screw (924doorEG)
Warm the car up completely. Disconnect the IACV. turn the idle screw (in to slow it down/out to speed it up) till it idles at 600-750 RPM. Reconect the IACV. It should have a check engine light till you urn the car off then restart.
Crxdriver1989
Dec 19, 2017 01:28 AM
CHANCELLOR12
Feb 6, 2016 03:46 AM
black bandit
Jan 14, 2008 04:26 AM
BDogggUT34
Jan 18, 2005 04:05 PM
oi-punx
Nov 14, 2002 02:01 PM
