ls no vtec.. need help!!
Old Nov 18, 2007 | 07:08 PM
behindblueyez19's Avatar
Default ls no vtec.. need help!!
ive got a 88 crx.. with a b18 block and b16 head.. did the head gasket on it.. now i have no vtec, and no power AT ALL.. but i know it could be a few things, so what are those few things so i can start checking.. thanks in advance.
Old Nov 18, 2007 | 08:07 PM
strawberry's Avatar
Default Re: ls no vtec.. need help!! (behindblueyez19)
check vtec ground
what head gasket did you use should be from a ls
double check your timing also
Old Nov 18, 2007 | 10:45 PM
im throwing codes 5 and 6, map sensor. and ect sensor.. so what should i do now?
and where should the vtec ground be at??
Old Nov 18, 2007 | 11:32 PM
charlee's Avatar
Default Re: (behindblueyez19)
first off, did you get your timing gears in the right spot? the vtec pressure switch which is at the bottom of your vtec solenoid has 2 wires, one is connected directly to ground, and the other one goes to your computer, since its a ""switch" its self explanatory that it closes ground to the computer indicating that there is sufficient oil pressure, thus allowing vtec engagement. so see if its even connected, OR if it even has a ground.
engine coolant temp its just maybe unplugged and/or has broken wires
map sensor may have a bad connection no vacuum going to it. if the map is disconnected it will hardly even run or start.
go back to the basics and check TIMING as strawberry said
Old Nov 19, 2007 | 04:11 AM
ludesrv's Avatar
Well usually a good place to start is to fix all the CEL. Check your map. I know for a fact a bad map sensor (enough to throw a code) can cause some serious bogging and it would have a hard time staying idle.
Old Nov 19, 2007 | 08:11 AM
fixed the map.. still doing the same ****.. ect is all hooked up right so it may be a bad sensor, but that still shouldnt make the car run like ****. so it may be off timing a little bit.. gonna check that today.. thanks guys i'll keep you informed of what happens
Old Nov 21, 2007 | 12:02 PM
strawberry's Avatar
Any CEL means no vtec if memory serves me right, definently an ECT code.
Old Nov 21, 2007 | 12:03 PM
strawberry's Avatar
Sorry wrong user name.
Tmfw
Feb 11, 2011 08:55 PM
dointhemzs
Nov 13, 2008 02:59 PM
theEGkid
Apr 20, 2005 07:56 AM
CustomizeHI808
Nov 27, 2003 02:19 PM
43MA
Dec 5, 2002 02:32 PM
