Removing factory gauge needles. (important)
Old Jun 24, 2002 | 05:26 PM
Attoir's Avatar
Default Removing factory gauge needles. (important)
How ya' do it?
Old Jun 24, 2002 | 05:29 PM
ef civic's Avatar
Default Re: Removing factory gauge needles. (Attoir)
use a fork and pry the needle up gently and don't mix up the needles or it won't work and put it back in the same positions.........peace
Old Jun 24, 2002 | 07:21 PM
bryant's Avatar
Default Re: Removing factory gauge needles. (ef civic)
If your putting indilgo gauges on, or some type of aftermarket guages. Dont remove the needles at all. Just slide them over the needles. If that does work use the above suggestion, and remember to be really carefull.
Old Jun 24, 2002 | 09:24 PM
spettinger's Avatar
Default Re: Removing factory gauge needles. (CR-X)
do not remove the needles!!! noo!!! your measurements will be forever screwed up! slide the guage faces over the side of the needle.
Old Jun 24, 2002 | 09:31 PM
Chris_'s Avatar
Default Re: Removing factory gauge needles. (wreckedhatch)
i broke my ****.....
don't remove the needles
you will end up buying a new cluster
muddmonky
Oct 17, 2012 11:24 AM
Mrfeee1
21
Dec 10, 2003 08:09 AM
Attoir
Jun 24, 2002 07:09 PM
Mikeveli
May 29, 2002 01:33 PM
uNF$@#!
May 22, 2002 07:13 PM
