Suspension & Brakes Theory, alignment, spring rates....
Wheel/Tire/suspension? (upgrade)
Old Nov 18, 2007 | 03:38 PM
AccordCD5's Avatar
Default Wheel/Tire/suspension? (upgrade)
My accord now sits with a 2.25" drop in front and 2.00" drop in rear and I have AGX's. I have on 15" OEM wheels and the standard 195/60/15 tires. I want to upgrade to a 17" wheel with 215/45/17,or would 215/40/17 be more appropriate?
anyway my question is: If I upgrade wheels without changing over to coilovers how will my ride height be affected? I do not have the cash to change up my springs/shocks. I want my tires to be flush with the wheel well.
any ideas or pics of a 5th accord gen on H&R race springs and 17" wheels?
Thanks
Old Nov 19, 2007 | 04:56 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
pics of your car now might help.
If you have some gap now and you want to get rid of it w/o changing springs and shocks, then you would have to get larger diameter tires. That will lessen fender gap, BUT it will also raise the entire car as well, making it actually ride higher.
Old Nov 19, 2007 | 09:53 AM
Targa250R's Avatar
be professional
Default Re: Wheel/Tire/suspension? (AccordCD5)
In addition, I would recommend sticking with a 205/45-17 tire as it is the closest in diameter to the stock 195/60-15.
Old Nov 19, 2007 | 01:56 PM
AccordCD5's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">If you have some gap now and you want to get rid of it w/o changing springs and shocks, then you would have to get larger diameter tires. That will lessen fender gap, BUT it will also raise the entire car as well, making it actually ride higher.</TD></TR></TABLE>
That's what I thought, and was affriad of. I think I might go with ground controls matched to my AGX's. I want to go koni yellows but I can't afford that and wheels/tires at one time. I waited long enough for larger wheels.
Thanks
adoboNkanin
Suspension & Brakes
Sep 29, 2008 03:42 PM
subhu1030
Sep 22, 2007 01:50 PM
rathead81
Dec 25, 2006 10:29 PM
yamaroket
Aug 24, 2006 03:32 PM
