Suspension & Brakes Theory, alignment, spring rates....
Skunk2 coilover sleeve part number help (ef)
Old 11-17-2007, 04:03 PM
chirp the 1-2's Avatar
Default Skunk2 coilover sleeve part number help (ef)
I picked up a set of used skunk2 coilover sleeves for my 89 hatch and im worried they are for a teg. the part numbers on the springs ended in 008 and 010.
Im also not sure which threaded body is for front or rear. Taller or shorter?
Please help
Thanks in advance
Old 11-17-2007, 08:27 PM
be professional
Targa250R's Avatar
Default Re: Skunk2 coilover sleeve part number help (chirp the 1-2)
The 10 and 8 kg-mm springs are for the Integra application. Skunk2 Civic street kits come with 8 and 6 kg-mm springs. They will still work on the car, but obviously will be a bit stiffer.
The taller sleeves go in the rear. Check here for installation instructions (PDF format): http://www.skunk2.com/Suspensi...OVADJ
Old 11-18-2007, 03:59 AM
thank you so much!
Old 11-19-2007, 05:03 PM
hyperdb2's Avatar
Default Re: (chirp the 1-2)
dont buy skunk2 **** sucks
usdm_ED7
10-09-2010 04:55 PM
redCJOteg
05-31-2004 03:25 PM
efvader
10-29-2002 07:27 PM
Quick Reply: Skunk2 coilover sleeve part number help (ef)
