rear camber on ITR w/ stock springs + bilstein shocks
Old Jun 24, 2002 | 04:54 PM
tjtruong's Avatar
New User
Default rear camber on ITR w/ stock springs + bilstein shocks
What does everyone run? I have a camber kit and set it at -1.40 rear and it seems good but that is the absolute max according to the allowance from the mechanic. I was trying to eliminate the excessive oversteer I was experiencing. So if people would post what their rear camber is set at on their R , it would be great. Any input would be appreciated. Thanks
Thomas
[Modified by tjtruong, 1:55 AM 6/25/2002]
Old Jun 24, 2002 | 07:45 PM
Big Phat R's Avatar
Default Re: rear camber on ITR w/ stock springs + bilstein shocks (tjtruong)
How are you getting oversteer with the stock suspension? Something doesn't sound right......
What tires are you running? What tire pressures? Under what driving situation are you experiencing "too much oversteer"
Read this first: (a good article btw)
http://www.se-r.net/car_info/suspension_tuning.html
Old Jun 24, 2002 | 07:53 PM
Bob#455's Avatar
Thomas, with your suspension setup, oversteer was likely caused by tire pressures... Did you have this problem at Buttonwillow?
Old Jun 25, 2002 | 01:46 AM
Unlimited's Avatar
New User
did you put your bilsteins on lowest setting?
if so hows the drop on it
Old Jun 25, 2002 | 08:41 AM
tjtruong's Avatar
New User
Default Re: rear camber on ITR w/ stock springs + bilstein shocks (Unlimited)
settings? I thought they were self adjusting? are you talking about the ride height? I noticed a small drop maybe .25 or so, but I Just installed them with the collar all the same on each shock. BTW, -1.4 camber in the rear is still within specs, but I was wondering if the tire would wear quick because I have azenis and want it to wear evenly.
thomas
Old Jun 25, 2002 | 08:55 AM
Eeepers's Avatar
New User
thomas
1.4 deg is fine, your tires will last a long time still.
Old Jun 25, 2002 | 05:21 PM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
what kind of kit do you have? 1.4 deg is the max it physically allows?
Old Jun 26, 2002 | 05:40 PM
tjtruong's Avatar
New User
Default Re: rear camber on ITR w/ stock springs + bilstein shocks (frank@b16a.com)
the brand is some generic brand called GSR, but what I meant was that the alignment machine specified that anymore would be out of stock ITR specs. The kit allows for i believe +/-3 degrees if i remember correctly. So i just set it at that so i could try to make the alignment close to factory specs if not just a little negative. Remember my car was lowered before and now has stock suspension back on so therefore that is why I have a camber kit. I just never took it off in the rear. Thanks for the info guys, I think i'll just leave it at that setting and see how my tires like it. Hopefully it won't wear out too fast.
Thomas
microfunk5
Suspension & Brakes
Dec 8, 2010 10:10 PM
Wish2345
Jul 28, 2010 08:29 AM
Nat X Stl
Suspension & Brakes
Jul 24, 2007 05:29 PM
teddy_dc2
Jun 22, 2005 09:17 AM
IMMORTAL-B18
Sep 8, 2004 10:56 PM
