valve cover?
ok so i have some paint sitting around that i used to paint my side skirts its cover green pearl or what ever, its Honda paint i got from the dealer. i wanna paint my valve cover to match my car. so my question is if i lay a few coats of high temp primer and then put down a few coats of the clover green and some clear would it chip or flak off b/c of the heat or would i be ok? and how many coats of each do you think i should use to be safe?? thanks for any help or advice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedoKing »</TD></TR><TR><TD CLASS="quote">ok so i have some paint sitting around that i used to paint my side skirts its cover green pearl or what ever, its Honda paint i got from the dealer. i wanna paint my valve cover to match my car. so my question is if i lay a few coats of high temp primer and then put down a few coats of the clover green and some clear would it chip or flak off b/c of the heat or would i be ok? and how many coats of each do you think i should use to be safe?? thanks for any help or advice
just make sure that the color you wanna lay down is high heat. I'm not sure about the clear coat though, I haven't seen any clear that is high heat. I'm currently doing my cover, jsut finished the primer, wrinkle red tomorrow
</TD></TR></TABLE>just make sure that the color you wanna lay down is high heat. I'm not sure about the clear coat though, I haven't seen any clear that is high heat. I'm currently doing my cover, jsut finished the primer, wrinkle red tomorrow
looks good but for some reason i thought that if you put down a high temp. base you could put down any kind of paint w/o any problems but i could be worng
if i cant paint it to match my car i may do white wrinkle or black
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers »</TD></TR><TR><TD CLASS="quote">YOU DO NOT NEED TO USE HIGH HEAT PAINT. THE VALVE COVER DOESN'T GET MORE THAN 300 DEGREES. THERE WAS SOMEONE THAT COVERED THEIR VALVE COVER IN PAPER MACHE' AND HAD NO PROBLEMS WITH IT.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers »</TD></TR><TR><TD CLASS="quote">YOU DO NOT NEED TO USE HIGH HEAT PAINT. THE VALVE COVER DOESN'T GET MORE THAN 300 DEGREES. THERE WAS SOMEONE THAT COVERED THEIR VALVE COVER IN PAPER MACHE' AND HAD NO PROBLEMS WITH IT.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers »</TD></TR><TR><TD CLASS="quote">YOU DO NOT NEED TO USE HIGH HEAT PAINT. THE VALVE COVER DOESN'T GET MORE THAN 300 DEGREES. THERE WAS SOMEONE THAT COVERED THEIR VALVE COVER IN PAPER MACHE' AND HAD NO PROBLEMS WITH IT.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers »</TD></TR><TR><TD CLASS="quote">YOU DO NOT NEED TO USE HIGH HEAT PAINT. THE VALVE COVER DOESN'T GET MORE THAN 300 DEGREES. THERE WAS SOMEONE THAT COVERED THEIR VALVE COVER IN PAPER MACHE' AND HAD NO PROBLEMS WITH IT.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers »</TD></TR><TR><TD CLASS="quote">YOU DO NOT NEED TO USE HIGH HEAT PAINT. THE VALVE COVER DOESN'T GET MORE THAN 300 DEGREES. THERE WAS SOMEONE THAT COVERED THEIR VALVE COVER IN PAPER MACHE' AND HAD NO PROBLEMS WITH IT.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers »</TD></TR><TR><TD CLASS="quote">YOU DO NOT NEED TO USE HIGH HEAT PAINT. THE VALVE COVER DOESN'T GET MORE THAN 300 DEGREES. THERE WAS SOMEONE THAT COVERED THEIR VALVE COVER IN PAPER MACHE' AND HAD NO PROBLEMS WITH IT.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers »</TD></TR><TR><TD CLASS="quote">YOU DO NOT NEED TO USE HIGH HEAT PAINT. THE VALVE COVER DOESN'T GET MORE THAN 300 DEGREES. THERE WAS SOMEONE THAT COVERED THEIR VALVE COVER IN PAPER MACHE' AND HAD NO PROBLEMS WITH IT.</TD></TR></TABLE>
that isn't angry.
this is angry
now that is quite angry
that isn't angry.
this is angry
</TD></TR></TABLE>now that is quite angry
at what temperature and for how long?
im hoping to do this over my Christmas vacation so i jus wanna make sure that im not going to mess it up. im going to do a high temp primer (i know i dont need hight temp but for peace of mind and jus to be safe) then put down a few coats of clover green pearl bake it then put a few coats of clear. also how long do you think this will last on a DD. would i be safer jus doing wrinkle paint?
