Bad suspension?
Old Nov 18, 2007 | 08:34 AM
f23accord's Avatar
Default Bad suspension?
I have a 2002 accord sedan thats dropped with Eibach Sportlines and some aftermarket camber kits. For the past few months I've been getting this CLINK/CLUNKing noise from the passenger front side when I go over bumps (not speed bumps). I haven't been able to get an answer to what it might be causing the problem and it only happens just in that area. I want to narrow down what the problem may be before I take it into a shop to have it fixed. If you guys could provide me with some input I would appreciate it, thanks in advance!
Old Nov 18, 2007 | 12:55 PM
loup05's Avatar
Default Re: Bad suspension? (f23accord)
who isntalled the springs? maybe they werent installed right.. we had a volvo s40 in the shop theother day that had that same problem.. turned out it was the bearing under the strut tower.. kinda hard to explain.. we actually replaced both bearings on the front along with the towers.. hope this helps
Old Nov 18, 2007 | 01:51 PM
f23accord's Avatar
Default Re: Bad suspension? (loup05)
My friends and I were the ones that installed the springs, they worked/sounded fine till now.
Edit: How hard was the work to replace the bearings under the strut tower? If possible could you post some pics to what/where exactly you were referring to?
Old Dec 1, 2007 | 03:51 PM
loup05's Avatar
WELL IM NOT SURE IF ITS THE SAME KIND OF SET UP FOR HONDA.. SORRY NO PICS.. AND IT WASNT HARD AT ALL ON A LEVEL FRM 1-10 I'D GIVE IT A 1... U DO HOWEVER HAVE TO TAKE OF FTHE SPRING
Kat620
Jan 18, 2012 11:20 AM
92inprogress
May 19, 2005 08:41 AM
92BlueCivic
Feb 16, 2004 10:53 AM
Kellindal
Jun 15, 2002 09:09 AM
