head gasket question
Old Nov 18, 2007 | 07:21 AM
ej1252's Avatar
Default head gasket question
when replacing the head gasket, do you need machine work to be done???
if so like what???
Old Nov 18, 2007 | 11:55 PM
ej1252's Avatar
Default Re: head gasket question (ej1252)
TTT
Old Nov 19, 2007 | 03:50 AM
Jdmb16sir2's Avatar
Only if the head has been damaged or the motor ever overheated, but its alway a good idea to have the head checked when is off.
Old Nov 19, 2007 | 07:51 AM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej1252 &raquo;</TD></TR><TR><TD CLASS="quote">when replacing the head gasket, do you need machine work to be done???
if so like what???</TD></TR></TABLE>
pressure check and resurface.. could replace valve seals and guides if they are bad.. or if you have the money for it... if not then just pressure check and resurface...
Old Nov 19, 2007 | 12:33 PM
Z you later's Avatar
I did a head gasket and we just replaced the head gasket with no head work done to it and it runs great not sure if it was warped I guess I will soon find out if it blows it again.
Old Nov 19, 2007 | 12:39 PM
h22crxpwr's Avatar
Default Re: (Z you later)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Z you later &raquo;</TD></TR><TR><TD CLASS="quote">I did a head gasket and we just replaced the head gasket with no head work done to it and it runs great not sure if it was warped I guess I will soon find out if it blows it again.</TD></TR></TABLE>
you sure will....
mackadocious
18
Jul 2, 2008 05:57 PM
drumminforev
11
Jan 4, 2007 01:39 PM
Squirtin EGsr
17
Sep 26, 2005 09:13 PM
WOODman
Jun 6, 2005 04:08 PM
sonicmoremusic
Sep 28, 2004 11:32 PM
