Auto to manual engine swap help
Old Nov 18, 2007 | 05:59 AM
carson_s13's Avatar
Default Auto to manual engine swap help
Hey guys. I have a 92 integra ls. my motor went bad so i pulled it and bought a donor car to pull a motor out of. The donor car had an automatic trans and my car is a 5 spd. I put my manual trans on the motor and dropped it in, and wired everything up. Now it wont start and im thinking it probably has something to do with different wiring harnesses. Has anybody been here before? or have any idea what i should do? i need help
Old Nov 20, 2007 | 04:41 PM
SEATownboi08's Avatar
Default Re: Auto to manual engine swap help (carson_s13)
What year is the donor car? No shouldnt be a problem make sure all is wired up right. In order for the car to run you need spark, compression and fuel soo its either your not getting spark or the motor has no compression..
Old Nov 21, 2007 | 03:53 PM
carson_s13's Avatar
Default Re: Auto to manual engine swap help (SEATownboi08)
the motor came out of a 92 as well, it turns over like it would if it were going to start but it never fires up. i know its getting fuel so ill check to see if it has spark when i get a chance. i had to pull the white plastic connector guide from inside of the main connector to get them to lock together so thats why i thought there may be a difference.
TheDonOG
Jan 1, 2017 01:25 PM
cehcivic15
Feb 18, 2009 08:13 AM
carson_s13
Nov 18, 2007 05:48 AM
noob101
Jul 23, 2006 02:45 PM
ef8b16a1
May 25, 2005 05:55 PM
