charcoal canister removal
Old Nov 17, 2007 | 09:01 PM
kixcrx's Avatar
Default charcoal canister removal
ok so i removed my charcoal canister and i read other threads on how to remove it and reroute the vaccum lines but i wanted to make sure if i did it right so i posted some pics. Is this right way to do it?
in this pic routed the gas line vent to the wheel well u can see the orange line going towards the wheel well
Modified by kixcrx at 12:24 AM 11/18/2007
Old Nov 17, 2007 | 09:12 PM
freddysEF's Avatar
Default Re: charcoal canister removal (kixcrx)
ya i also want to know
Old Nov 17, 2007 | 09:25 PM
kixcrx's Avatar
Default Re: charcoal canister removal (freddysEF)
ANYBODY KNOW?
Old Nov 17, 2007 | 10:22 PM
kixcrx's Avatar
if anybody knows or had done this please let me know if i did it right before i drive my car around like this thinking i did it right and something bad happens.
Old Nov 17, 2007 | 10:54 PM
CRXed's Avatar
Here is how I ran mine. I have since removed the charcoal canister purge solenoid completely and tucked the map sensor under the intake manifold. I'll take more pics tomorrow.
Old Nov 17, 2007 | 10:59 PM
kixcrx's Avatar
Default Re: charcoal canister removal (CRXed)
is it true i have to disconnect the 2 wire connector (solenoid) because i read somewhere that i have to unplug it. Did u unplug yours
Old Nov 17, 2007 | 11:07 PM
CRXed's Avatar
I was running it capped off, but it was plugged in. I pulled the plug out and ran around the block and performance was fine, no codes. The function of that solenoid is to allow vapors from the canister into the intake during acceleration only. If you have no canister, well, take that ish out. I have one of those two ports on the intake manifold capped. I forget which one but you'll see in pics tomorrow.
Old Nov 18, 2007 | 09:49 AM
layedoutat0psi's Avatar
wow ive never actually thaught about gettin rid of the canister, but it looks so nice without it there. somone please post what all you have to do to get rid of it.
Old Nov 18, 2007 | 12:00 PM
CRXed's Avatar
Default Re: (layedoutat0psi)
I ran the fuel tank vent line down to a plastic tube coming out of the bottom of the firewall / shock tower area.
Old Nov 18, 2007 | 12:02 PM
Tippyman's Avatar
Looks ok to me. If it runs fine then it is. If it surges, you got a leak.
Old Nov 18, 2007 | 01:33 PM
kixcrx's Avatar
Default Re: (Tippyman)
ok so i can cap off the one the comes from the tb and from the back of the manifold and get rid of the purge solenoid because it looks to me i connects to the tb and the back of the manifold
Old Nov 18, 2007 | 01:50 PM
Default Re: (CRXed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXed &raquo;</TD></TR><TR><TD CLASS="quote">
I ran the fuel tank vent line down to a plastic tube coming out of the bottom of the firewall / shock tower area.</TD></TR></TABLE>
hey crxed your valve cover hose is off
anyways what about the big cluster on the firewall???
Old Nov 18, 2007 | 02:39 PM
CRXed's Avatar
When you take the purge solenoid off all you are left with is the map sensor. You can take off the whole mounting assembly. I zip tied the map sensor to my intake manifold for now, going to mount it to the TB later on.
Old Nov 18, 2007 | 03:09 PM
kixcrx's Avatar
Default Re: (CRXed)
ok so this is what i did i removed the purge solenoid so it looks likes this now
and in this pic this is what i capped off does this look right
Old Nov 18, 2007 | 07:23 PM
Crx Jimmy's Avatar
Default Re: (kixcrx)
make sure you dont cap off the vent from the gas tank its the fitting on the firewall that went to the canister, just run a hose from it and let it hang down a foot or so, if its capped off it can cause problemns with pressure in the fuel system
Old Nov 18, 2007 | 07:37 PM
HondaFerris's Avatar
Default Re: (Crx Jimmy)
he allready pointed out what he did with the gas tank vent in his first post...and the way he did it is better than just letting it hang down.
Old Nov 21, 2007 | 05:56 PM
now what do i do about the hose coming off of the fuel presure regulator???? do i just run it to a spot on the intake manifold or what?
Old Nov 21, 2007 | 06:30 PM
anyone?
Old Nov 21, 2007 | 07:15 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by layedoutat0psi &raquo;</TD></TR><TR><TD CLASS="quote">now what do i do about the hose coming off of the fuel presure regulator???? do i just run it to a spot on the intake manifold or what?</TD></TR></TABLE>
Yes.
Old Dec 31, 2007 | 09:38 PM
zkelley's Avatar
i was wondering what did you do with the hard vacuum lines on the back on the intake manifold. if you can post me a pic of the back of your intake manifold it would help me alot! i ran mine like you have yours but it ran like crap and i figured i had some hoses backwards or somethin wasnt capped off so im not sure. thanks
Old Jan 1, 2008 | 12:25 AM
Civic_kid_666's Avatar
what the hell is a carcole canister what does it do ?????
Old Jan 1, 2008 | 12:35 AM
kixcrx's Avatar
Default Re: (Civic_kid_666)
catches fuel vapors from gas tank
dkrex001
Sep 27, 2006 11:03 AM
B18C Turbo
Aug 30, 2006 07:11 PM
downest
Jun 13, 2006 09:01 PM
hOndafienD 04
Oct 19, 2004 12:21 PM
Dutchie
Jun 24, 2002 10:22 PM
