what bushings are the same on the ef as the eg or ?
i would like to replace my bushings. the thing is i really don't want urathane and OEM is just so expensive. there is a company that is called hardrace but they only make bushings for eg, ek and DC. so what bushing from these will work. if you only know of a couple that your sure will work but not on the entire chassis just let me know the ones you sure of. i just think that you should be able to put together a package using couple from the eg, a couple form the ek.
let me know.
Thanks
let me know.
Thanks
Not sure about the rest of the chassis, want to know as well. I thought I read somewhere that we can use the rear trailing arm bushings on the EF but I could be wrong.
I picked up HardRace's shifter bushings last week and installed the blue bushings, but whats the black one for?
