Will this work??? auminum exhaust
Old Nov 17, 2007 | 07:50 PM
bigTom's Avatar
Default Will this work??? auminum exhaust
Has anybody ever tried this? I know that aluminum exhausts work; But will it work pre-turbo? It's 6061 tubing going into a stainless adaptor piece that will be home to the wastegate. Welcoming all opinions!
Old Nov 17, 2007 | 07:54 PM
k24em2's Avatar
Default Re: Will this work??? auminum exhaust (bigTom)
Don't run antilag....lol Might be gettin kinda close to the limit of that 6061 though
Old Nov 17, 2007 | 09:04 PM
Fat Head
Guest
Posts: n/a
Old Nov 18, 2007 | 05:20 AM
Bailhatch's Avatar
Default Re: Will this work??? auminum exhaust (Fat Head)
I would not do that
Old Nov 18, 2007 | 10:36 AM
.RTErnie's Avatar
Default Re: Will this work??? auminum exhaust (Bailhatch)
What thickness of aluminum is that? I'll be definitely interested in seeing how well it holds up. you should take into account the fatigue characteristics. And yield strength at temperature.
Old Nov 18, 2007 | 12:38 PM
civic.slow's Avatar
* B A N N E D *
Default Re: Will this work??? auminum exhaust (.RTErnie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">Don't run antilag....lol Might be gettin kinda close to the limit of that 6061 though</TD></TR></TABLE>
dude anti lag would be sick in that thing imagine a car backfiring then bam the exhuast shoots out of the bottom of the car hahha
Old Nov 18, 2007 | 01:47 PM
tony1's Avatar
Default Re: Will this work??? auminum exhaust (civic.slow)
Heat is one thing, heat and pressure is a whole different ballgame. I wouldn't give it long. Judging by the fact that it's not welded up, i'm guessing you feel the same and thought it would be funny to make a post about it? lol
Old Nov 18, 2007 | 08:23 PM
bigTom's Avatar
exactly what i was thinking... but i dont know!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">I would not do that</TD></TR></TABLE>
care to go any further into detail as to why you would not do that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RTErnie &raquo;</TD></TR><TR><TD CLASS="quote">What thickness of aluminum is that? I'll be definitely interested in seeing how well it holds up. you should take into account the fatigue characteristics. And yield strength at temperature.</TD></TR></TABLE>
roughly .065" i believe...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Heat is one thing, heat and pressure is a whole different ballgame. I wouldn't give it long. Judging by the fact that it's not welded up, i'm guessing you feel the same and thought it would be funny to make a post about it? lol</TD></TR></TABLE>
Thats the same mindset I have. He's willing to try it. The turbo's are in the back of the car so I'm building I guess really long 3" up-pipe's connecting the headers to the turbo's. One thing I have also been thinking about is running at the track vs. on the dyno with the whole heat issue.
I really don't know if it will work or not. I think it will!
Old Nov 18, 2007 | 10:11 PM
.RTErnie's Avatar
Its a bad idea as far as turbchargers are concerned....
You want the largest temperature and pressure drop as possible across the turbine wheel... making the pre turbine piping out of aluminum will dissipate the heat at a much higher rate than the ss... lowering your dT across your turbine wheel.
Try doing thermal coatings inside and out... and measure temperature loss with some temp probes...that would an interesting comparison (alum raw, alum coated, mild steel, 304ss, 316ss, inco)
Old Nov 18, 2007 | 11:47 PM
k24em2's Avatar
haha, give it a shot but hang the turbo with some extra safety wire just in case
Old Nov 19, 2007 | 02:42 AM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigTom &raquo;</TD></TR><TR><TD CLASS="quote">
fatigue problems mostly, but now that I know it's at the back I agree with what ernie said about loseing some of your energy. Why not use some 18g stainless? it's pretty light too.
Old Nov 19, 2007 | 08:27 AM
Lubo_25's Avatar
im still trying to figure out why ppl use aluminum for high heat exhaust applications especially on turbo setups stainless steel for the win comrade
but thats my .02 cents...
Old Nov 19, 2007 | 09:31 AM
levelzero's Avatar
I've seen aluminum adapter flanges (for bolting a turbo to a stock manifold) melt.
6061 has a melting point of 1090*F.
5052 has a melting point of 1130*F.
7075 has a melting point of 900*F
Old Nov 19, 2007 | 09:39 AM
tony1's Avatar
Default Re: Will this work??? auminum exhaust (levelzero)
My guess is 1000+ deg F and 30psi pressure inside the alum. tube will make a very interesting looking aluminum balloon!
Old Nov 19, 2007 | 09:56 AM
paulzy's Avatar
Default Re: Will this work??? auminum exhaust (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">My guess is 1000+ deg F and 30psi pressure inside the alum. tube will make a very interesting looking aluminum balloon! </TD></TR></TABLE>
maybe it'll be like blowing glass
Old Nov 19, 2007 | 10:40 AM
Lubo_25's Avatar
exceptional webpage texan comrade...keep on truckin
Old Nov 19, 2007 | 11:36 AM
k24em2's Avatar
Yea.....hes gonna have a 3" tube instead of a 2" tube rather quickly
Old Nov 19, 2007 | 05:29 PM
.RTErnie's Avatar
Default Re: Will this work??? auminum exhaust (k24em2)
aluminum oxide has a much higher melting point than 5-6000 series alumium
FYI 7k series aluminum isn't weldable and can't be mandrel bent like that
Dont put any load on it...and minimize the stress on the part..and I bet it lives longer than you think weld some heat sinks on it too.. lol
Old Nov 19, 2007 | 09:35 PM
beepy's Avatar
Yes but aluminum oxide forms a layer less than a mil thick and it is brittle. When you weld aluminum, any oxide forms "tectonic plates" over the puddle. It's not going to keep the manifold from melting or deforming.
I just don't understand why people are willing to risk so much for a little weight savings. Why not use Titanium tubing? Cheaper than buying a new exhaust every 2 races.
Old Nov 19, 2007 | 09:55 PM
DESTROYER's Avatar
Fence post.
/Thread
sd_ej1
Sep 2, 2008 05:01 PM
Top Ramen
Welding / Fabrication
30
May 22, 2008 08:31 PM
06 Habanero-NaVi
Honda Civic (2006 - 2015)
36
Jan 10, 2007 05:01 AM
globlctzn
Honda Motorcycles
19
Mar 13, 2005 10:49 PM
shamun
Apr 23, 2003 01:39 PM
