broke down crx need help pls
Old Nov 17, 2007 | 04:46 PM
Rickdogg's Avatar
Default broke down crx need help pls
can someone pls help me my car broke down and it dont wana start and i dont have the money 2 put it in the shop rite now but i cant find out wats wrong with it the day it broke down my car overheated then about 2 hours later i went to go start it and it started up find but then it just shut off all of a sudden and the it wouldnt start after that i did a basic tune up on it fuel filter plugs etc.... i also check the pump its running and i had a guy look at it and he said its my distributor but i dont wana get one and its not that ya know can anyone give me some pointers
Modified by Rickdogg at 9:19 AM 11/18/2007
Old Nov 17, 2007 | 06:25 PM
Rickdogg's Avatar
Default Re: broke down crx need help pls (Rickdogg)
bump
Old Nov 17, 2007 | 06:53 PM
instrument's Avatar
you need a multimeter and a helms manual to diagnose it properly.
well, thats what i would use....
Old Nov 17, 2007 | 07:12 PM
i-want-a-crx's Avatar
Default Re: (instrument)
if you want you can pull the carpet back under the dash count the number of light flashes through the ecu and google it.
should tell you what your problem is.
but it isnt 100% sure, a shop is always your best bet but if your like me...
if your car overheated maybe your distributor rotor got warm and pooped out, if you count 8 flashes on the light thats your problem.
my rotor got a tad hot or something put a new distributor in and works. if you dont know how to put one in and not have to go through the timing pm me.
Old Nov 17, 2007 | 11:40 PM
CRX Toad's Avatar
Default Re: (i-want-a-crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-want-a-crx &raquo;</TD></TR><TR><TD CLASS="quote">if you want you can pull the carpet back under the dash count the number of light flashes through the ecu and google it.
Why not just look in the FAQ at the top of the forum seems easier than Google
Old Nov 18, 2007 | 08:13 AM
Rickdogg's Avatar
aight thanks ill check my ecu out i got a helms book 2 dont u have to mark a spot or something on the distrib to change it with out doing the timing?
Old Nov 21, 2007 | 06:28 AM
Rickdogg's Avatar
Default Re: (Rickdogg)
i tried checking that light on the ecu and it dont even flash how do u get it to work haha
Old Nov 21, 2007 | 06:33 AM
mr.speaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rickdogg &raquo;</TD></TR><TR><TD CLASS="quote">i tried checking that light on the ecu and it dont even flash how do u get it to work haha </TD></TR></TABLE>
key to the on position
Old Nov 21, 2007 | 06:52 AM
Rickdogg's Avatar
Default Re: (mr.speaker)
i did that and it only flashes once then nothing
Old Nov 21, 2007 | 07:21 AM
90efhatch's Avatar
there are no codes then.
Old Nov 21, 2007 | 08:13 AM
stillsmokey's Avatar
Default Re: (90efhatch)
Does it turn over, do you have spark?
Old Nov 21, 2007 | 08:15 AM
Default Re: (stillsmokey)
If not, i would suggest changing the Ignitor in your dist, or just replace the distributor.
Old Nov 21, 2007 | 08:19 AM
wiZCo's Avatar
Stouts 'n' Scotch
Ummm..... maybe we should be asking why the car overheated in the first place?
Old Nov 23, 2007 | 02:29 PM
Rickdogg's Avatar
thats good theres no code but my car still wont start im gona try and buy a distrib. from HAP. ya it turns over but not on some guy that looked at it said i have a weak spark and it might be my distributor but i dont know if hes right cause he just works on cars on the side not his job. my radiator has a crack in it i think that why its overheating or my thermostat
phillyk89
Oct 2, 2009 08:07 PM
Bump
Aug 30, 2006 04:50 PM
rob42386
Sep 30, 2005 12:42 PM
s2khondauk
Honda S2000
Feb 19, 2005 03:59 AM
DeDonDeRosa
Dec 1, 2003 04:31 PM
