99 converted si problems help
i got a converted 99 dx into an si... it has the b16 a2 motor and trans dc race headers and a shortram intake, it also has a chipped p30 computer obd1 converted harness...... and one 02 sensor
i jus picked this car up not to long ago and it started throwin codes....
it is miss firing like **** and it wont let me rev out past 3600 rpms
does anyone know possiblities of what is wrong
If the car was a 99 and you have a b16a2 then why did you convert to OBD1. You should just run an Ecu out of a 99 Si (P2T I believe) and use a harness out of a 99-00 Si...
Get your codes read? If it wasnt throwing the codes when you bought it with the swap then your o2 sensor probably went bad somewhere along the way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryank327 »</TD></TR><TR><TD CLASS="quote">Get your codes read? If it wasnt throwing the codes when you bought it with the swap then your o2 sensor probably went bad somewhere along the way</TD></TR></TABLE>
Chipped computer don't even use the O2 since it's in open loop, and can't use an OBD2 Generic/Factory to read it since the computer is OBD1, but this is what I will definitely do first:
- Check the wires/terminals to the ecu for opens or loose connections
- Then check the soldering on the ecu
- If all that is done, last thing to suspect is the person did not take off "CheckSum" and the ecu is rejecting the program causing it to run on default. ie: can't rev past 3500rpm
yeah i think the ecu needs to be re chipped and tuned.... im takin it to philly dyno works tomorrow to get dyno tuned..... its definetly sensor related... so thats what i tihnk im gonna go do
zildjianmatt
Feb 11, 2010 07:09 AM
ballplayer
17
May 11, 2005 03:45 AM
