block gridle question help
can i use a gridle from one GSR to another GSR block? i heard that i need to use the same gridle that came on that block no mis matching should be done with the mains and the gridle. Is that true will i mess somthing up if i dont use the same gridle on the same block?????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laziebun »</TD></TR><TR><TD CLASS="quote">can i use a gridle from one GSR to another GSR block? i heard that i need to use the same gridle that came on that block no mis matching should be done with the mains and the gridle. Is that true will i mess somthing up if i dont use the same gridle on the same block?????</TD></TR></TABLE>
You can use them, BUT you better do a line hone.
pogeeboy27
Paint and Body
Mar 6, 2008 11:34 AM
b16a4
25
Jul 16, 2007 08:15 AM
X2BOARD
Apr 29, 2002 07:41 AM
