4thgen preludes help pls
Old Nov 17, 2007 | 01:48 PM
BB1LOViN's Avatar
Default 4thgen preludes help pls
for those of you with 4thgen preludes.. is there any other alternative to the motorized antenna?
what would i need to get something like the s2000 or short antenna?
Old Nov 17, 2007 | 01:55 PM
Acidcrakker's Avatar
Default Re: 4thgen preludes help pls (BB1LOViN)
You really should be able to uninstall the power antena and install any other antenna you want. You just have to know what your doing.
Old Nov 17, 2007 | 01:57 PM
93sivtec's Avatar
Default Re: 4thgen preludes help pls (Acidcrakker)
Its super easy....I got like a 13" rubber off ebay called a euro style antenna or something.....it looks more modern,and it fits in like a breeze,but the reception sucks so if u r into the radio at all,dont buy the ones off of ebay,get a quality brand.Just type in prelude antenna in your search and u will see.
BB1LOViN's Avatar
is it a simply plug and play?i have no experience with cutting wires etc.
thanks for the quick response
Old Nov 17, 2007 | 01:59 PM
Most likely you will have to remove the power and negative wires to the power antenna or cap them off. The other wire should just plug in
Old Nov 17, 2007 | 02:00 PM
93sivtec's Avatar
Yes it just plugs in....u have to remove like 2 screws and the antenna facia,swap it out and bam,plug it in...u are good to go.
Old Nov 17, 2007 | 02:10 PM
glazethatj's Avatar
i just unplugged it so it stayed down. i never listen to the radio
Old Nov 17, 2007 | 02:21 PM
BB1LOViN's Avatar
thanks for all the replies
what about the s2000 antenna? should i get an oem one and will it also be a plug and play?
Old Nov 17, 2007 | 02:31 PM
mattsnooz's Avatar
they are plug and play. Most are even universal now I believe. Mine was 14 dollers and reception is awsome. You can get them anywhere pretty much
You won't have anyprolems. Just take your time and maybe mask around the antenna so you don't accidently scratch anything.
Old Nov 17, 2007 | 02:34 PM
prelude_93vtec's Avatar
when we got the car, the power was broken so we jus installed this one. i sure do miss the power one though
Old Nov 17, 2007 | 09:48 PM
BlackCatt's Avatar
I did the same as glazethatj and just unplugged the power and left the antenna down. I hardly ever listen to the radio but if i want to it still gets awesome reception while i am in the city. Installation of a new antenna is quite simple as others have said, just dont be in a rush and scratch your paint work.
Old Nov 17, 2007 | 10:02 PM
Default Re: 4thgen preludes help pls (BlackCatt)
IMO the power antenna is retarded. If you ever look at it while your out of the car It will remind you of an RC Car.
Old Nov 17, 2007 | 11:43 PM
AmauryR's Avatar
I had a old VW-style roof antenna mounted on my fender. razr cam pics, they suck but should show what it looks like. Only thing you need is a rather large washer and it fits fine. Angles just enough so it points up, and it sits maybe 1" higher than the roofline. mast screws off when I wash the car, so its just perfect. I also have a "shorty" mast that screws in, switch it up once in a while. Amd the reception is great, especially for those crystal clear radio commercials!
-l8r
Old Nov 18, 2007 | 12:15 AM
autoluder's Avatar
if you dont have a visor, you can get an interior antenna, that mounts to the glass, that was my plan originally, then I got lazy and just disconnected the antenna wire from the back of the cd player.
Old Nov 18, 2007 | 03:12 AM
samurhai's Avatar
Default Re: (autoluder)
i got mine off of ebay
http://cgi.ebay.com/ebaymotors...wItem
Old Nov 19, 2007 | 09:59 PM
BB1LOViN's Avatar
Default Re: (samurhai)
thanks for all the help...
how does your EBAY antenna work for reception?
Old Nov 19, 2007 | 11:19 PM
samurhai's Avatar
i've noticed a little better reception than oem. when i had the oem antenna, i couldn't get reception in my garage, but after i got the ebay one, i get better reception.
Old Nov 23, 2007 | 06:32 PM
BB1LOViN's Avatar
hey thats a nice paint job you got there. is it all orginal or did you geta repaint?
Old Nov 24, 2007 | 12:13 AM
MLBZ521's Avatar
I went through the annoying antenna not moving, but making loud noise crap.. When I got my first Radio, I unplug the old antenna and I bought a hidden antenna.. I didn't really install it any where, just plugged it up. It worked fine if I sat it on the dash, but in the floor it was great..
When I moved out to AZ I zip tied it under the dash, under the Passenger Airbag, and it had terrible reception there.. And also pulled the stock antenna cable out and tied it up in the trunk.
Then over Xmas last year, out here in AZ, my car was broken into and my headunit and rear speakers were stolen.. Put my stock deck back in and it gave power to the stock antenna, so I had to go unplug the power from it.. After I finally got a new deck for my B-Day this past summer.. When I installed it, I relocated the hidden antenna to the top of my dash.. Now it sits inside the dash, above the cluster on the passenger side.. I get fine reception there when I do listen to the radio..
I also removed the entire antenna assembly from my car. Lost a few pounds there..?
I'd recommend the hidden antenna if you want to listen to the radio sometimes.. It's light as anything, no weight to it at all.. And you can completely remove the stock system.
Old Jan 19, 2008 | 12:35 PM
yroachy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">IMO the power antenna is retarded. If you ever look at it while your out of the car It will remind you of an RC Car.</TD></TR></TABLE>
maybe... but it looks so much nicer when it's tucked away... I'd rather have it hide itself when I'm listening to a cd than constantly being up...
Old Jan 19, 2008 | 12:53 PM
Default Re: 4thgen preludes help pls (yroachy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yroachy &raquo;</TD></TR><TR><TD CLASS="quote">
maybe... but it looks so much nicer when it's tucked away... I'd rather have it hide itself when I'm listening to a cd than constantly being up...</TD></TR></TABLE>
That is the same thing I said. And please dont bring up 2 month old threads just to state an opinon.
Old Jan 19, 2008 | 05:11 PM
VTecLude1994's Avatar
Just got mine back from some body work. I removed mine and had the hole welded shut. I never listen to the radio anyway.
Old Jan 19, 2008 | 06:50 PM
BB1LOViN's Avatar
Default Re: 4thgen preludes help pls (VTecLude1994)
sweet! i was thinking that too. did you have it repainted as well?
i was thinking about just bondo-ing the hole and spraying it myself.
do you have any pictures please?
Old Jan 19, 2008 | 07:10 PM
RyanStevenPhillips's Avatar
Are there any that can go in the fender or something. When I look at a 5th gen I have no idea where the antenna is, but when I listen to their radio...Crystal CLEAR! I want that in my car. Maybe this guy does too!?
Old Jan 19, 2008 | 07:19 PM
BB1LOViN's Avatar
Default Re: 4thgen preludes help pls (RyanStevenPhillips)
on my last 2003 Camry it had an "in-glass anteanna",but sounds pricey.
