A/C Question (help)
Old Nov 17, 2007 | 01:35 PM
VTECdohcter's Avatar
Default A/C Question (help)
i have a gsr in my hatch and im using the sohc a/c compressor which bracket would i need to be able to mount the a/c compressor
Old Nov 17, 2007 | 02:39 PM
Default Re: A/C Question (VTECdohcter)
need to know!!!
Old Nov 18, 2007 | 02:41 PM
Bump!!!
Old Nov 18, 2007 | 02:43 PM
ke98248's Avatar
have patience.
Old Nov 18, 2007 | 02:55 PM
egsleepercivic's Avatar
97 crv braket PJ7, cost about half as much as the Delsol vtec P54 bracket, either will work, you will also need the components for the idler pulley for the Delsol vtec
gl
Old Nov 18, 2007 | 03:11 PM
Default Re: (egsleepercivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">97 crv braket PJ7, cost about half as much as the Delsol vtec P54 bracket, either will work, you will also need the components for the idler pulley for the Delsol vtec
gl </TD></TR></TABLE>
what do u mean i will need the components fo he idler pulley for the delsol vtec?
are u trying to say if i use th delsol 1?
Old Nov 18, 2007 | 03:54 PM
there is a arm that attaches the pulley to the bracket, one bolt/screw that attaches the arm to the bracket and an allen screw that attaches the pulley to the arm you need both screws and the arm, it doesn't matter which bracket you use PJ7 or P54, you will still need the arm and screws
Old Nov 18, 2007 | 03:57 PM
you need # 12, 22, 15, 13, 18, 23, 24, 25 in this pic
http://slhondaparts.com/browse...=true
Old Nov 18, 2007 | 04:57 PM
josephcitr's Avatar
you need 1994 del sol vtec a/c compressor braket good luck it should fly
Old Nov 18, 2007 | 05:46 PM
Default Re: A/C Question (josephcitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by josephcitr &raquo;</TD></TR><TR><TD CLASS="quote">you need 1994 del sol vtec a/c compressor braket good luck it should fly</TD></TR></TABLE>
get 97 crv its the same and cost about half as much, I just did this in my 92 with a crv bracket
Old Nov 18, 2007 | 07:40 PM
k man thnx will look for it thanx for help
lmike6453
Apr 1, 2008 05:41 AM
pkgwjai082
Jun 17, 2006 02:36 PM
99lspwr
Feb 25, 2005 03:44 PM
Edwardo911
Oct 5, 2004 06:04 PM
