broken frame mount
Old Nov 17, 2007 | 08:06 AM
layedoutat0psi's Avatar
Default broken frame mount
well all of a sudden my alternator started hitting the frame when i go into reverse sometime and when i go around sharp corners. i was int he garage one day workin on my car and i notice the passangers side motor mount were its welded to the frome has cracked and is almost all the way disconnected. has anyone had this problem before? there is no rust or anyhting in that area so i dont kno why it did it. its just a clean crack like somone cut it. il post up pics latter after i get out of work.
Old Nov 17, 2007 | 01:24 PM
2point2's Avatar
Default Re: broken frame mount (layedoutat0psi)
grind off the spot welds and take it completely off.
Go to the autowreckers with a chordless drill and drill out the welds on your new mount
weld the new one in and you're done.
might have to take off the tranny.. but that's the gist of it.
Old Nov 18, 2007 | 02:07 PM
Default Re: broken frame mount (2point2)
well i finally got some pics of my cracked mount/frame
Old Nov 18, 2007 | 02:14 PM
1989CivicSi's Avatar
Pretty easy fix as mentioned above. Your options are drill out the spotwelds/do as mentioned above and weld in a new mount...or go K/H series .
Old Nov 19, 2007 | 04:15 AM
2point2's Avatar
Default Re: broken frame mount (1989CivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1989CivicSi &raquo;</TD></TR><TR><TD CLASS="quote">or go K/H series . </TD></TR></TABLE>
Lol, the car is doing the sawp for you!
Old Nov 19, 2007 | 05:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">
Lol, the car is doing the sawp for you! </TD></TR></TABLE>
lol, upon closer inspection though...
I didn't notice before because I posted in a rush (saw the thread and had to do something), but that's the first time I've ever seen a frame crack like that. Does your car have cancer/been in a collision before? Pretty much the same fix, but you may need to cut and patch a panel on that rail with thicker or equivalently gauged steel. A bit more complex than lining up the spotwelds and welding, but if this is a low HP application you might as well give it a try just to learn.
Good luck with the repairs!
Old Nov 19, 2007 | 08:11 AM
no the car is not rusty at all in that area and has never been in a collision from what i kno and see
KickStart2323
Mar 8, 2007 06:23 AM
Haruspex
Feb 19, 2005 08:51 AM
JMD
Nov 28, 2004 10:54 AM
turbospool
Aug 8, 2003 11:49 PM
