sup guys iv got some msd questions
Old Nov 17, 2007 | 04:05 AM
jdmvtec@413's Avatar
Default sup guys iv got some msd questions
iv got a blaster now wat r the other things that i need n how to install it
Old Nov 17, 2007 | 06:00 AM
spray_bombed's Avatar
mmm... a cap and rotor for an external coil setup and a coil wire to run from the coil to the external cap
Old Nov 19, 2007 | 04:50 PM
Default Re: (spray_bombed)
hey thanx does it have 2 be msd
Old Nov 19, 2007 | 05:06 PM
yoffer's Avatar
Banned
That would be preferable. What other company makes a cap with an external coil?
Old Nov 19, 2007 | 05:33 PM
Default Re: (yoffer)
theres other iv seen some
Old Dec 31, 2007 | 02:53 PM
riggs_rz's Avatar
hey guys. i bought a 97 CX not long ago (new to hondas). i found a coil in the trunk. good thing i found this post. so to make the coil work i need one of these right?
http://cgi.ebay.com/ebaymotors...ZWDVW
if i decide to buy it and install it. what advantages will i get? thanks.
Old Dec 31, 2007 | 09:36 PM
Tru2Less's Avatar
question.....what is msd really used for more sparks?
Old Dec 31, 2007 | 09:47 PM
4gencivicef9's Avatar
Default Re: sup guys iv got some msd questions (jdmvtec@413)
You need a MSD Cap with a external coil, the blaster pak or the coil, and the plug wires....
what you need to do is take your stock dizzy cap off and you will see this coil pak on top with two wires going to it. you have to drill a tiny hole through the dizzy cap the MSD one and send them wires to the new blaster pak, so that means soldered and extend the wires to the old coil to the new blaster pak. The have markings if you don't know which one is + and - then reinstall you cap and then the new plug wires and then thats basically it...
Good luck you really dont need this, most people dont run this until they our high horsepower..
Old Jan 1, 2008 | 02:41 AM
bpkmrtoes's Avatar
Default Re: (Tru2Less)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tru2Less &raquo;</TD></TR><TR><TD CLASS="quote">question.....what is msd really used for more sparks?</TD></TR></TABLE>
Yes, depending on rpm, MSD discharges more spark on the power stroke to make a more complete burn.
rriicckk787
Jun 29, 2005 06:58 PM
_oemek_
Aug 16, 2004 04:16 PM
