FS: 95 Civic Cx Hatchback (CLEAN)
***SOLD***
***SOLD***
***SOLD***
***SOLD***
For Sale: White 95 Cx Hatchback. Has a clean title, never been in an accident. The paint is original and still in mint condition mainly because the car has always been covered and detailed regularly. The body has no major dents or scratches and I always get compliments on how clean it is. Recently did a tune-up on it and all fluids were changed. Car runs and handles great. I rarely drive the car in fear of getting jacked so I recently Non-op'ed it. Comes with the following stuff
<U>Engine</U>
B16A3 Motor
Del Sol Dual core radiator
Walbro 255 fuel pump
Whale ***** intake
4-1 Header w/ 2.5 collector
Car Sound high flow cat 2.5"
2.25 Piping with magnaflow Muffler
<U>Trans/Drivetrain</U>
UKDM LS Trans
ACT Street Strip Clutch Disk
ACT Heavy Duty Pressure Plate
Lightened Type R Flywheel 12.8lbs
<U>Suspension/Wheels</U>
H&R Race springs
Front shocks are Koni yellows, rears are stock
Front and rear GSR swaybars
Front and rear GSR brake conversion with new rotors and pads
Front and rear stainless steel braided brake lines
Front and rear camber kit
15x6.5 Bronze Konig Heliums
Falken Azenis RT610 almost brand new.
<U>Interior/Electronics/Exterior</U>
Apex'i Auto timer
Viper Paging alarm system
Panasonic headunit
GSR front seats
Carpet is out because I had it cleaned (will be installed before its sold)
Real deal Vision Smoked Amber corners
The bad
-Using PR3 ecu and throwing O2 sensor malfunction code
-No Heater (lines are looped)
-Has Ice Cold A/C but one of the hardlines has a hole(will replace and recharge before its sold).
I'm probably forgetting some parts, will post up engine pics soon along w/ compression test numbers
Located in Fontana/Bloomington.
EDIT: <U>Added engine pics/ Just did a compression test...210 PSI on all cylinders
</U>
<U>***Test drives will only be given to people who are seriously interested...By serious I mean you have cash in hand.***</U>
Modified by s.patel at 5:46 PM 11/17/2007
Modified by s.patel at 8:06 PM 12/1/2007
***SOLD***
***SOLD***
***SOLD***
<U>Engine</U>
B16A3 Motor
Whale ***** intake
UKDM LS Trans
H&R Race springs
Apex'i Auto timer
Panasonic headunit
GSR front seats
The bad
</U><U>***Test drives will only be given to people who are seriously interested...By serious I mean you have cash in hand.***</U>
