my window only goes up with alwarm
94 civic coupe ex
(atleast to me ).. for the past month my pasenger side window will go down when pressed by the driver switch but WONT GO UP !!!! it only went up through the passenger door..NOW it wont go up at all , or atleast through the switches it onyl goes up when I arm my alram ??????
WTF !!!!!!????????????????
Replace your driver's side window switch assembly. You should be able to get one from a local scrapyard for cheap.
If you don't think that's the problem, run a test light to and from all the leads as per the diagnostic test in your Helms manual. No Helms manual? Then you shouldn't be working on your car. Take it to a mechanic.
thats wat im planning on doing on tomorow...(mon) .. hopefully its just the switch!!! just it was a bit WEIRD , ive had my share of hondas and this has never happend!!!!
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Did you have auto windows with the alarm, Like a dei 529t 0r 530t window modual?
Bj Reynolds
Oct 30, 2015 01:37 AM
Blockhead G
Aug 14, 2002 06:30 AM
