Woah! Did I do damage at Laguna Seca?
Old Nov 16, 2007 | 04:45 PM
Eyal 951's Avatar
Default Woah! Did I do damage at Laguna Seca?
Check these out. My valve lash is WAY out of spec after the Laguna Seca event last weekend. Constant high rpm revving with valvetrain, and crower 3 cam, it seems like the little tappet things mushroomed and deformed! Am I right, or do they look normal?
I did a valve adjustment today anyway. Some of the exhaust lash were at about .050! I set em to .005 for now, I am still unsure if they are actually deformed.
Old Nov 16, 2007 | 05:31 PM
IntegraType-R's Avatar
um...
Old Nov 16, 2007 | 06:03 PM
itralex's Avatar
Default Re: (IntegraType-R)
bent valves?
Old Nov 16, 2007 | 06:18 PM
Fat Chick Magnet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R &raquo;</TD></TR><TR><TD CLASS="quote">um...</TD></TR></TABLE>
x2
Old Nov 16, 2007 | 06:46 PM
GhostAccord's Avatar
Default Re: (dc2rtek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itralex &raquo;</TD></TR><TR><TD CLASS="quote">bent valves? </TD></TR></TABLE>
Why do you say bent valves? If your looking at the #2 cylinder valves being down a bit that is probably because of the position of the cam in it's rotation at the time the pic was taken????
Hard to tell with the oil drops on them, but they look OK. In that first pic the #2 exhaust valve tappet on cylinder #1 looks out of whack but that could just be the lighting and the angle. If they are that far out of spec there is something that has moved. Spring, valve seat, valve lock seating??? Is this the first time you have run them hard? maybe your valve train just finally settled. If your worried about them it will probably only set you back #50-#70 to replace them all.
Modified by GhostAccord at 11:57 PM 11/16/2007
Old Nov 16, 2007 | 11:05 PM
b18bEKcoupe's Avatar
Mechanical lash and a hard weekend. Re adjust and thats about all you can do. Everything "looks" fine but a picture in this case isnt worth a thousand words.
Old Nov 17, 2007 | 06:14 AM
WrongWD's Avatar
Default Re: (GhostAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhostAccord &raquo;</TD></TR><TR><TD CLASS="quote">
Why do you say bent valves? If your looking at the #2 cylinder valves being down a bit that is probably because of the position of the cam in it's rotation at the time the pic was taken???? </TD></TR></TABLE>
this was going to be my suggestion. a simple compression test will tell you if you have bent valves if that is your concern
Old Nov 17, 2007 | 09:21 AM
d16dcoe45's Avatar
Default Re: (WrongWD)
I take it you don't have the cam installed in those pics? If not, why does the #2 cylinder ex. valve appear to be sitting lower? If the cam is removed and the valves are still sitting lower on #2--chances are they are not returning to the seat which would indicated they probably tapped and bent a little, so now they are stuck in the guide.
Old Nov 17, 2007 | 11:50 AM
Fat Head
Guest
Posts: n/a
Old Nov 17, 2007 | 12:19 PM
Eyal 951's Avatar
Default Re: (d16dcoe45)
The cam is in there. The only thing removed from this motor in these photos is the valve cover. There are NO bent valves. #2 is sitting lower because the are resting on the cam lobe.
All I'm unsure about is the tappets, whether they look damaged or their fine.
Old Nov 17, 2007 | 12:31 PM
WrongWD's Avatar
Default Re: (Eyal 951)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eyal 951 &raquo;</TD></TR><TR><TD CLASS="quote">The cam is in there. The only thing removed from this motor in these photos is the valve cover. There are NO bent valves. #2 is sitting lower because the are resting on the cam lobe.
All I'm unsure about is the tappets, whether they look damaged or their fine.</TD></TR></TABLE>
i'd say wick up the oil on them and take another picture. it's difficult to tell from that photo
Old Nov 17, 2007 | 08:44 PM
inh's Avatar
inh
at least im not the only one who posts the same exact stuff on multiple forums
Old Nov 18, 2007 | 03:36 AM
Thrizzle's Avatar
* B A N N E D *
Tappets look beat.. I would change them then do a valve adj.
Far left tappet = deformed
Right tappet = ok-ish.
Old Nov 18, 2007 | 03:48 PM
turboZChatch's Avatar
Default Re: (Thrizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrizzle &raquo;</TD></TR><TR><TD CLASS="quote">Tappets look beat.. I would change them then do a valve adj.
Thats what I was looking at also the far left tappet looks deformed.......How does something like that happen heat? hirev mishifts? valve lash not set correctly?can anyone fill me in kinda interested
Old Nov 18, 2007 | 06:42 PM
Eyal 951's Avatar
Default Re: (inh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inh &raquo;</TD></TR><TR><TD CLASS="quote">at least im not the only one who posts the same exact stuff on multiple forums
haha, just here and naturally aspirated on D-series.org.
Old Nov 19, 2007 | 05:49 AM
bump because I am curious as to how this happened
Old Nov 19, 2007 | 04:49 PM
PyroProblem's Avatar
Default Re: Woah! Did I do damage at Laguna Seca? (Eyal 951)
Yes Id say those tappets are definately shot.
I would replace all of them.
Just like you assumed. High rpm and stiff springs caused that. How high are you spinning it? Maybe a hair tighter on the lash or heat treating the new tappets would help...
Old Nov 19, 2007 | 05:09 PM
Default Re: Woah! Did I do damage at Laguna Seca? (PyroProblem)
On that second pic.It looks like there might be a hairline crack on the rocker. The one with "2" cast it. Do you see it or is it just the picture?
Old Nov 20, 2007 | 12:48 AM
Blind-Fashion's Avatar
Look fine to me, I just went and checked the spare set in my garage.
BLacK FirE
May 24, 2006 05:30 PM
turbotime
Mar 31, 2006 06:21 AM
slipstreamsi
Jun 2, 2004 12:14 PM
david90
Aug 8, 2003 06:25 AM
NomacGSR
Aug 1, 2003 05:19 AM
