How do you put those tiny little keepers into the retainers?
Old Nov 16, 2007 | 04:20 PM
sup3rd's Avatar
Default How do you put those tiny little keepers into the retainers?
I'm having a hard time =\ it took me a while just to get done with one valve. How have you other guys done it? I wanna get this over with already
Old Nov 16, 2007 | 04:23 PM
mgags7's Avatar
I use surgical scissors to get them in, then the round end of two small paint brushes to maneuver them around, but some spring compressors give enough room to use your fingers.
Old Nov 16, 2007 | 04:41 PM
sup3rd's Avatar
dang, I can't fine any good spring compressors for this h22 =\
Old Nov 16, 2007 | 06:22 PM
Rosko's Avatar
Default Re: (sup3rd)
what kind of compressor do you have?
Old Nov 16, 2007 | 06:37 PM
98vtec's Avatar
moderator emeritus
Default Re: (Rosko)
pen magnet
Old Nov 16, 2007 | 07:53 PM
PirateMcFred's Avatar
Default Re: How do you put those tiny little keepers into the retainers? (sup3rd)
1 pair needle nose pliers.
2 .062" thk x ø.125" neodymium magnets
1 valve spring compressor
1 steady hand
Old Nov 16, 2007 | 08:05 PM
98vtec's Avatar
moderator emeritus
Default Re: How do you put those tiny little keepers into the retainers? (PirateMcFred)
sweet! i like that one!
Old Nov 16, 2007 | 08:08 PM
Rosko's Avatar
Default Re: How do you put those tiny little keepers into the retainers? (98vtec)
coolness
Or you could use your fingers.
Old Nov 16, 2007 | 08:25 PM
LudeBehavi0r's Avatar
https://honda-tech.com/zerothread?id=2143227
Thats pretty much what I did, with a little help of my magnetic friend in the pictures that I took.
Old Nov 16, 2007 | 09:30 PM
sup3rd's Avatar
Default Re: (Rosko)
Right now I'm borrowing the c shaped one form auto class =\ its not doing the job.. what kind of valve spring compressors do I need?
Old Nov 16, 2007 | 09:34 PM
sup3rd's Avatar
Default Re: (LudeBehavi0r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">Or you could use your fingers.</TD></TR></TABLE>
How come your head doesn't look as deep as mine..
Old Nov 16, 2007 | 10:00 PM
vinuneuro's Avatar
I just used my fingers too. Hold the retainer at an angle and just drop it in. I coated the inside of the keepers in petroleum jelly before dropping them in the retainers. Helps them seat on the valve stem when installing.
You do have the retainers in your hand and not in the engine when putting the keepers in right?
Old Nov 16, 2007 | 10:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sup3rd &raquo;</TD></TR><TR><TD CLASS="quote">How come your head doesn't look as deep as mine..</TD></TR></TABLE>
umm... what? I don't understand the question given the context of the pic I posted and the topic of the thread.
please elaborate.
Old Nov 16, 2007 | 10:56 PM
sup3rd's Avatar
Default Re: (PirateMcFred)
please elaborate.</TD></TR></TABLE>
sorry that was a noob mistake quesiton<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">
You do have the retainers in your hand and not in the engine when putting the keepers in right?</TD></TR></TABLE>
what do you mean by that? i just got another valve in! woohoo! I'm ghetto fabbing this so I don't have much room to work with lol. I'll post up pics of what im using to compress later
Old Nov 19, 2007 | 05:05 PM
sup3rd's Avatar
Look at my ghetto spring compressor!
Old Nov 19, 2007 | 09:12 PM
I would think doin it with the head sitting like it would on the block would make it a lot easier. Gravity will be on ur side and it'll keep you from dropping a few more f-bombs in the process
Old Nov 20, 2007 | 02:30 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeBehavi0r &raquo;</TD></TR><TR><TD CLASS="quote">dropping a few more f-bombs in the process</TD></TR></TABLE>
my car
Old Nov 20, 2007 | 05:16 AM
flyrod's Avatar
Default Re: (mgags7)
There is also the zip-tie method:
https://honda-tech.com/zerothread?id=1881352
Old Nov 20, 2007 | 09:25 AM
Lubo_25's Avatar
long tweezers and a dab of moly lube works for me...
Old Nov 20, 2007 | 09:41 AM
JasonST's Avatar
Default Re: How do you put those tiny little keepers into the retainers? (Lubo_25)
If u have a friend that can help you out you can just use a box end of a wrench to compress the spring, then use tiny needle nose pliers to seat them in place. there's plenty of methods on here, give em a try and see which one works best for you.
Old Nov 20, 2007 | 02:42 PM
sup3rd's Avatar
haha im done. i used that ghetto set up. and woooow the zip tie one looks great! i gotta try that some day
JDM_SOHC
Mar 23, 2012 01:42 PM
HumanResource
Jan 8, 2009 07:31 AM
EFinawesomeman
Jan 4, 2009 10:13 PM
Fezzie
12
Aug 21, 2006 12:49 PM
