Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
This is driving me insane
Old Nov 16, 2007 | 10:27 AM
Nighthawk7thGen's Avatar
Default This is driving me insane
So has anybody ever experienced an issue with the drivers side door cutting out sound to all the speakers in your car as soon as the hinges are fully open and touch metal-on-metal with themselves or as soon as the door touches the latch mounted to the door jam / body of car? (or anything else metal for that matter.......)
Thats exactly whats happening to me right now and im about to rip the door straight off
oh god please help
Old Nov 16, 2007 | 10:58 AM
thinknology's Avatar
Default Re: This is driving me insane (Nighthawk7thGen)
I'd say you have a wire grounding out on your door mate.
Old Nov 16, 2007 | 10:59 AM
Psychochik's Avatar
Yeah and thats not something you really should ignore !!
Old Nov 16, 2007 | 11:02 AM
Default Re: (Psychochik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Psychochik &raquo;</TD></TR><TR><TD CLASS="quote">Yeah and thats not something you really should ignore !!</TD></TR></TABLE>
troof... Kind of surprised he hasn't blown a fuse...
Old Nov 16, 2007 | 11:06 AM
Default Re: (thinknology)
well i disconnected the drivers side front door from the rest of the harness and everything works as supposed to with the drivers door disconnected from power completely...so i know its in that door's harness somewhere....
what could it be....or how can i bypass this? (i.e. running a ground cable from door to negative terminal of battery?)
Old Nov 16, 2007 | 11:09 AM
daddy's Avatar
Default Re: (Nighthawk7thGen)
its prolly best to try to fix the problem and not just bypass it.
Old Nov 16, 2007 | 11:11 AM
Default Re: (daddy2be)
well its 20 degress out and th fingers r numb....i think ill bypass it for now. so...how would I go about doing THAT?
lol...this is afro engineering tho
Old Nov 16, 2007 | 11:17 AM
daddy's Avatar
well youve already isolated the problem to teh drivers door. so check for freyed wires or spots where it could be grounding. you definitely have a short somewhere. coudl be in the harness where it goes bwteen the dash board and the door. since you said it happens when the door is fully open
Old Nov 16, 2007 | 11:20 AM
already pulled the rubber housing off and disconected the wires that run out from under the dash into the drivers door. when the drivers door is totally disconnected the drive door does not effect anything (obviously). So...the wires from dash to door are all good. idk...maybe a pin came loose from one of our plastic male wiring harness connectors? (but ive disconnected and reconnected all of those and had no trouble there (i.e. loose pin inside connector etc))
getting close...nothing yet though
Old Nov 16, 2007 | 11:25 AM
daddy's Avatar
sounds like its just gonna be trial and error. good luck
Old Nov 16, 2007 | 12:58 PM
as long as the speaker connection that plugs in seperately under that dash in unplugged theres no grounding issue and all 3 other speakers and my subs work.
Thats the only way around this Ive found so far. Is there any way to tap into the sound system's harness bypassing the connection under the dash? should i look to splice into a connection closer to the head unit? if anybody could still help at this point thad be great
thankya!
Old Nov 17, 2007 | 08:52 AM
alright...heres a compromise:
&gt; I've got 4 Pioneers in my car. All 4 are 6 1/2 160W Speakers.
&gt; As you all know. ONLY the wiring harness thats shorting my WHOLE drivers door is the speaker harness only.
&gt; As soon as the speaker harness for that door is unplugged from under the dash and the door makes contact with the body of the car it will not short. If plugged IN...it WILL short. (regardless if a speaker is connected, grounded etc. No Change there)
So to get to the point, the only thing Ive thought of to correct the issue its to splice Left rear and left front speakers together. If Im correct stereo in our cars involves 2 channels (left and right). We can choose to fade power to front or rear but that doesnt effect the stereo and is not a feature of stereo. So If I splice front speakers into the rears and fade the sound all the way to the rear speakers I should not hear a change and should recieve full sound intensisty thru all speakers.
Right?
Old Nov 18, 2007 | 05:01 PM
Fat Head
Guest
Posts: n/a
Default Re: This is driving me insane (thinknology)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thinknology &raquo;</TD></TR><TR><TD CLASS="quote">I'd say you have a wire grounding out on your door mate. </TD></TR></TABLE>
Old Nov 18, 2007 | 07:31 PM
alrighty...
lock it up. solved this issue
Old Nov 19, 2007 | 01:43 AM
Newborn_'s Avatar
Grace Under Pressure
Care to share for anybody else who might encounter a similar problem?
raphael
Paint and Body
11
Nov 8, 2007 05:36 AM
dingusjt
28
Jun 5, 2004 08:52 PM
accordfreak
Feb 21, 2004 11:51 PM
CB_ejcoupe
Jan 26, 2004 02:35 PM
FR-MOB: ThE bEe GuY
Jul 14, 2003 09:11 AM
