Camber Correction for 91 EF HF
sounds stupid to ask, but what kind of front camber correction do you guys use on crx???? having trouble locating the correct type......basically i do not want to use camber correction ball joint.....perfer upper control arm correct (eg: skunk2 front camber kit).....any suggestion???? or pretty much stuck with ball joint correction????
so far the only camber kit i found are ball joints.....do you have a prefer brand or type or know any website i should look at???
turning it into a street power race car.....need correct the camber for better traction and life to the tire........also be a daily driven car also......yes....alignment on the car is awsome......i hate to have butterfly wheels.............looks too ugly that why i ask if anyone has bought any upper control are camber kit....
try ingalls bushing kit. they reposition the inner bushings of the upper a arm. but theres really not a lot of room to push the camber out under the fender before hitting the fender frame. thats why you cant use anything like skunk2 arm adjusters. you can grind down the tip of the stock a arm for a litte extra clearance. just a bit.
keeping the camber straight is good only for drag racing. so as long as thats what you are after, then youll benefit from a camber kit.
bake1782
May 9, 2008 08:06 AM
b18LS
Suspension & Brakes
Apr 18, 2007 06:05 AM
Jonathan_ED3
22
May 18, 2005 12:36 PM
eTec
19
May 21, 2002 04:51 AM
