Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Type R sway bar with mount kit on GSR
Old Jun 24, 2002 | 01:34 PM
TurboInteg95's Avatar
Default Type R sway bar with mount kit on GSR
hmm well, I just found a deal (I think) for a Type R rear sway bar with a mount kit for a non type R. I think the mount kit was called BCg or BNG or something along those lines. Should I be worried at all about Tear outs? I am currently running H&R sport springs with KYB AGXes. The guy was saying hes only seen tear outs on cars with humongous rear sway bars and stock springs and shocks. any truth to this? thanks
Old Jun 24, 2002 | 01:43 PM
Weston's Avatar
Default Re: Type R sway bar with mount kit on GSR (TurboInteg95)
Do you mean the BSQ kit? Everyone says that's the best kit to get, and I haven't heard of any subframe tear out with it. I have heard of people having tear out with the Skunk2 bar, which is only 19mm, so size isn't the only factor leading to tear out.
Old Jun 24, 2002 | 01:58 PM
Default Re: Type R sway bar with mount kit on GSR (Weston)
Yes Weston I was just about to correct that, it was the BSQ kit. I think I might just pick up this bar then, $100 for the kit and the bar, does that sound reasonable?
Old Jun 24, 2002 | 02:56 PM
sutrusu's Avatar
thats a pretty good deal. is it used?
Old Jun 24, 2002 | 03:11 PM
AcuraRacer112's Avatar
Default Re: Type R sway bar with mount kit on GSR (sutrusu)
BSQ guy is on this board, SN BSQ name bret...cool guy i have the kit
Old Jun 24, 2002 | 03:24 PM
Willard's Avatar
http://www.hondatwincam.com/itr-srk.html
Old Jun 24, 2002 | 04:30 PM
RineRacing's Avatar
I have the ITR 23mm bar on my car with the BSQ mounting kit and it's been through 35+ autocrosses with no sign of tear out, and I drive my car hard.
Old Jun 25, 2002 | 09:25 AM
BSQ's Avatar
BSQ
FYI, you can purchase the Type-R rear swaybar, the necessary bushing, brackets, nut and bolts for ~$85 shipped from http://www.acuraautomotiveparts.net . You can purchase my BSQ Type-R rear swaybar mounting/reinforcement kit for $20 shipped. So you are looking at a total cost of ~$105.
Helpful information (links) on the Type-R rear swaybar:
Type-R rear swaybar installation instructions: http://www.geocities.com/bretq/swaybar_install.html
BSQ Type-R rear swaybar mounting/reinforcement kit: http://www.geocities.com/bretq/mounting_kit.html
Let me know if you have any questions...I will be glad to help you out.
Old Jun 25, 2002 | 11:51 AM
Frito's Avatar
Default have you guys just tried washers?
you know, to basically do the same as these kits...I think if you use the right washers that it would distribute the load pretty evenly anyway.
thanks
Francisco
Old Jun 25, 2002 | 12:22 PM
bps2799's Avatar
Default Re: have you guys just tried washers? (Frito)
You'd need a lot of washers to get the bottom of the bracket spaced correctly away from the subframe. $20 sounds cheaper and easier to me.
Old Jun 25, 2002 | 04:13 PM
It is a new bar and kit.
Old Jun 25, 2002 | 11:12 PM
Nacho169's Avatar
Best suspension mod ever (esp. considering price).
r1ch1e
Oct 14, 2006 06:42 AM
Maxboost808
Jun 16, 2004 02:01 PM
grngsr01
Feb 25, 2003 02:36 PM
ken-shin
Aug 26, 2002 01:35 PM
