bent front subframe?
Old Nov 15, 2007 | 09:02 PM
tatmark1's Avatar
Default bent front subframe?
Has any one had a bent front subframe? I replaced all bushings around car new control arms ball joints ect... I was in at the Honda dealer getting an alignment and the drivers side caster is off. they said that the subframe was probably bent.
Is this common? has anyone else had this. Did new subframe fix the bad caster if you had it?
Its a 95 vx
Old Nov 15, 2007 | 09:16 PM
ejoner's Avatar
Default Re: bent front subframe? (tatmark1)
It could cause bad caster from a bent subframe but it depends on how bad it is bent, also a bent strut can cause the same problem.
Old Nov 15, 2007 | 09:25 PM
tatmark1's Avatar
well i know any amount of bend on that subframe is going to throw it off. I would say its either that or lower control arm.
oh and it has new struts
Old Jun 21, 2011 | 06:15 PM
EJ1JDM's Avatar
IS YOUR TIRE SHIFTED BACK? cus my front pass tire is shifted back and my subframe might be bent i was told
Old Jun 21, 2011 | 07:21 PM
JDMxTai's Avatar
Has the car been in a wreck?
You must of hit some serious pot holes or something to bend it to effect caster.
Since you said you got new strut its probably subframes or lcas that are bent.
Better hope you bent the lcas though not the subframes
I'm so sorry mods I was.on my phone and I didn't see the date*
dHaybee
Suspension & Brakes
Apr 7, 2011 02:07 PM
jadugartir
Jan 6, 2008 12:16 PM
el_gzman
Suspension & Brakes
Jun 9, 2007 10:46 AM
TealEG!
Suspension & Brakes
Oct 20, 2005 08:24 PM
xcathodex
Mar 23, 2003 04:26 PM
