h22 hatch need advise?
i got a civic hatch obd1 with jdm h22 motor. I have a p28 with a h22 program and when i try to drive the car it starts bogging when i give it gas
when i unhook that ecu and i try a stock p28 it runs but not good of course, feels like it doesnt go anywhere
any idea what it can be? Thanks
where did the h22 program come from? most of the h22 bins ive seen out there are trash.
also, might want to doubble check your TPS calibration.
i got a p13, runs good only check engine light that is on it reads code 41 (Oxygen sensor)
Runs good with p13 but when you drive it feels real slow like it doesnt want to move...have to check timing
i just did the same swap in my eg and wen i star to go it boggs like crazy and just runs like **** then the idle will drop really low then shut off im runnin the stok jdm ecu but i want to know the answer to this question to????????????
make sure your map is good.. i just over came this problem. i had an h22 in my integra and it ran.. but it idled real rough during start up.. after i swapped that h22 into my civic.. it bearly wanted to turn over.. idled rediculously rough bearly drivable.. so i tweaked with teh idle stop screw and the idle adjust screw and replaced the iacv 2 or 3 times.. adjusted fuel pressure.. everything i could, so i decided, as a last hope to go back to the guy that mapped my p28 the first time.. after i got it back.. idled and ran better than it did before... perfect idle and 100% reliably drivable.
