b16a2......
so i just did my first b16 swap on my first eg hatch the car turns on but it runs shitty...
when i step on the gas it dies at idle...
and also i turned it on with my stock p06 dx ecu.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tigueremalo »</TD></TR><TR><TD CLASS="quote">and also i turned it on with my stock p06 dx ecu.....
This is probably a big part of your problem.
Have you double-checked your ignition timing also?
well engine came off my good running 2000 Si the engine was sitting for just 3 week i dont think the timing is off..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
Have you double-checked your ignition timing also?</TD></TR></TABLE>
i think the ecu is my problem....
the ecu and the wiring could be a big part depending on how shitty it is running then timming may be an issue it could have jumo a tooth or somthing crazy like that what codes is it showing..
well my ecu(p06) doesnt have the led for me to see.. the code
the only sensor i dont have plugged in is my iat sensor that is not plugged in
which i was thinking of eliminating anyway but am not sure if i can do that....?
