aftermarket rezister box
Old Nov 15, 2007 | 05:27 PM
ALL IMPORT's Avatar
Default aftermarket rezister box
need a high 2 low box for my teg cause ive meesed 2 up in the past year & now its meesed up my injectors so wondering if thier is a after market one out thier
Old Nov 15, 2007 | 05:43 PM
.RTErnie's Avatar
Default Re: aftermarket rezister box (ALL IMPORT)
they go from Low to High resistance.....
You need (2) 25 watt 10 ohm Resistors
DALE makes a nice anodized aluminum heat sinked resistors.
SDSEFI.com sells the same ones. I've personally used them on my car.
(if you're running sequential you'll need 4.)
Old Nov 15, 2007 | 06:14 PM
SIXTY's Avatar
Default Re: aftermarket rezister box (.RTErnie)
We used the sds ones with no problems
Old Nov 15, 2007 | 06:17 PM
SpeedDreamz.com's Avatar
AEM make a 10 injector driver box
Old Nov 15, 2007 | 06:42 PM
tony1's Avatar
Default Re: aftermarket rezister box (SpeedDreamz.com)
Yeah, get an injector driver and do it right. The car will run better anyways.
Old Nov 15, 2007 | 06:45 PM
ALL IMPORT's Avatar
Default Re: aftermarket rezister box (tony1)
it works right with the aem ems?
tony its been a while but im going to hit u up soon about the cam trigger just trying to get the car 2 run right first
Old Nov 15, 2007 | 06:51 PM
.RTErnie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, get an injector driver and do it right. The car will run better anyways. </TD></TR></TABLE>
bah dont listen to this guy...he only runs 9.30's
correction... 9.27's
Old Nov 15, 2007 | 07:37 PM
melovesboost's Avatar
Ive heard some good things about the FJO unit
http://www.fjoracing.com/products/injdrvr/
Old Nov 15, 2007 | 08:28 PM
reaction360's Avatar
Default Re: aftermarket rezister box (melovesboost)
if running an aem injector driver box, do you get rid of the oem resistor box or run it with it?
Old Nov 16, 2007 | 02:51 AM
ALL IMPORT's Avatar
Default Re: aftermarket rezister box (reaction360)
that would replace the oem bull sh*t
Old Nov 16, 2007 | 10:51 AM
wHOAlly's Avatar
yup. on our injector flow bench, with the popular bosch 160lbers ive seen ~40% increase in needed injector open time from using a driver to a resistor pack.
Old Nov 16, 2007 | 10:55 AM
tony1's Avatar
Default Re: aftermarket rezister box (wHOAlly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wHOAlly &raquo;</TD></TR><TR><TD CLASS="quote">
yup. on our injector flow bench, with the popular bosch 160lbers ive seen ~40% increase in needed injector open time from using a driver to a resistor pack. </TD></TR></TABLE>
Yeah, i've seen the exact same thing. With a honda computer and 1600's with the resistor box, it takes about 2ms at idle, with an injector driver it's more like 1.2ms.
Old Nov 16, 2007 | 12:35 PM
HR-1320's Avatar
Acceleronics inj drivers are nice. Look that up if your looking for a good box.
Old Nov 17, 2007 | 11:21 AM
boostedr's Avatar
Default Re: aftermarket rezister box (HR-1320)
i've got an fjo 8 channel driver for sale in the for sale section, barely used,its seen like 20 dyno passes thats it, parted the car out.
ekcoupeh22
Mar 29, 2012 07:21 PM
Justin Olson
Jul 30, 2008 09:03 AM
JBLAZE622
Mar 19, 2008 08:58 AM
Muckman
Feb 20, 2008 10:46 AM
turbod da
May 25, 2007 05:31 PM
