Reuse Thrust Washers?
Old Nov 15, 2007 | 03:19 PM
B18C_EJ8's Avatar
Default Reuse Thrust Washers?
Can thrust washers be reused?
Old Nov 15, 2007 | 04:04 PM
Crazydave's Avatar
Default Re: Reuse Thrust Washers? (B18C_EJ8)
why would you....
it's an $8.89 part that can cost you thousands
Old Nov 15, 2007 | 04:23 PM
RACEPAK's Avatar
Default Re: Reuse Thrust Washers? (Crazydave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave &raquo;</TD></TR><TR><TD CLASS="quote">why would you....
Not likly, if there is no endplay.......
EDIT: if endplay is within spec's.
Old Nov 15, 2007 | 04:41 PM
B18C_EJ8's Avatar
See, there's less than 1500 miles on the engine I tore down, so I figured I should be able to use them...
Old Nov 15, 2007 | 05:40 PM
Runnerdown's Avatar
Default Re: (B18C_EJ8)
if the bearings look mint and the end play is good then do it up
Old Nov 15, 2007 | 07:44 PM
onepoint6i's Avatar
you can reuse them..
Old Nov 15, 2007 | 10:23 PM
Default Re: (onepoint6i)
Get new ones.
Do it right the first time
Old Nov 16, 2007 | 04:19 PM
IN VTEC's Avatar
If they look like this, then definitely don't reuse them.
4drsedaneg
65
Apr 26, 2012 05:20 AM
misha
Mar 15, 2008 06:11 PM
TheThiefTheKnife'NTheGun
Jan 21, 2005 11:07 PM
cubism
Oct 5, 2004 06:11 PM
fivespeedintegra
Sep 18, 2003 10:03 AM
