lighting issue
Im not sure if this is where to post this but i know alot of people look here.
In my 93 hatch when i have my headlights on, my tail lights and instrument lights dont work. But when my headlights are off or just my corner lights are on, everything works fine. Someone please help.
thanks, fuses are all good, as for grounding points and such this just happened tonight, worked fine this morning ill check anything i can think of, anyone else.
well i found something out now i dont know what else to do, when i turn the headlight switch all the way on so headlights are on, my gauge lights and taillights dont work, but if i turn the switch so its kinda chillin between having running lights and headlights on everything works fine, so i guess it is in the switch, anyone know what it could be in the switch?
Quit bumping the post every 10 minutes be patient everyone is not going to stop doing what they are doing to help you. The switch can be shorted inside causing this to happen. Go pull a switch from the pick and pull and just connect it to yours to see if that fixes it. Pull all the steering column plastic casings off and look if any of the wires are cut or if the connector is loose.
lilmarcEH3
Jan 28, 2010 04:29 PM
klomast3r
Sep 6, 2005 01:52 PM
