GSR TURBO... leak
Old Nov 15, 2007 | 02:03 PM
jim9's Avatar
Default GSR TURBO... leak
Modified by jim9 at 10:29 PM 2/17/2008
Old Nov 15, 2007 | 02:17 PM
Flashmn's Avatar
Default Re: GSR TURBO... leak (jim9)
another turbo bites the dust thanks to shitty filters...
*knocks on wood* I have a similar filter on mine, hehe tho its not that close to the turbo
Well I dont think the oil is that bad, if you didnt run low on it when you got home...Its the vacuum that pulled it out of the turbo, because your turbo inlet was clogged and the engine needed air. Atleast the piping wont rust anyways, clean most of it out and fire up the car and see if theres any signs of damage (extra noises).
Old Nov 16, 2007 | 08:02 AM
NotBoostedEK's Avatar
Default Re: GSR TURBO... leak (Flashmn)
i dont have any filter on my turbo just a piece of metal screen bent over witha big zip tie to hold it on and i havent had a problem
Old Nov 17, 2007 | 07:49 AM
jim9's Avatar
Default Re: GSR TURBO... leak (NotBoostedEK)
Modified by jim9 at 3:10 PM 2/20/2008
Old Nov 17, 2007 | 01:13 PM
is it smoking when its running u may have blown the oil seals on the inside of the turbo if it is
Old Nov 17, 2007 | 03:15 PM
jim9's Avatar
Old Nov 18, 2007 | 07:57 AM
sounds to me like the oil seals in the turbo are blown your vaccumm lines and ic pipes and ic and pcv will all have oil in them cause the compreser wheel oil seal is shot/leakin suckin it into the motor and dont waste your time cleening it till u fix the seal and your motor is ok sounds like the problems in the turbo
Old Dec 14, 2007 | 08:22 AM
jim9's Avatar
Modified by jim9 at 3:09 PM 2/20/2008
Old Dec 29, 2007 | 10:18 AM
poorman's type-r's Avatar
* B A N N E D *
HAHAH... isnt karma a BLEACH... that was thanks to selling me a expletive pressure plate BLEACH!!! SCAMMER
ej1252
Oct 30, 2007 01:51 PM
mrbsponge
Jun 20, 2005 11:22 AM
kj98r
May 16, 2004 03:16 PM
bartek_b
Mar 18, 2003 08:01 PM
