P30 pistons in GSR
Old Nov 15, 2007 | 01:55 PM
M2S~Jaime's Avatar
Default P30 pistons in GSR
Any rules of thumb out there for P30 pistons in a GSR? Anything like retarding the distributor or adding more fuel and stuff like that?
Will be putting a motor together soon and would just like to know...
Thanks in advance.
Old Nov 15, 2007 | 02:16 PM
Fat Chick Magnet's Avatar
p30 pistons.
how about a nice tune to be safe in the end.
Old Nov 15, 2007 | 02:17 PM
whats your setup on the gsr? details please. curious to know.
Old Nov 15, 2007 | 02:18 PM
M2S~Jaime's Avatar
Default Re: (dc2rtek)
I wish. Out here on Guam... Haven't had a dyno in years.
Old Nov 15, 2007 | 02:21 PM
M2S~Jaime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2rtek &raquo;</TD></TR><TR><TD CLASS="quote">whats your setup on the gsr? details please. curious to know.</TD></TR></TABLE>
Just the basic stuff. Skunk2 manifold and 68mm TB, Toda Spec A2 cams, Supertech valvesprings & retainers, and then the P30's with a milled head. Will be getting a header sometime down the road.
Old Nov 15, 2007 | 02:29 PM
Default Re: (M2S~Jaime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2S~Jaime &raquo;</TD></TR><TR><TD CLASS="quote">
Just the basic stuff. Skunk2 manifold and 68mm TB, Toda Spec A2 cams, Supertech valvesprings & retainers, and then the P30's with a milled head. Will be getting a header sometime down the road.</TD></TR></TABLE>
yeah you're going to need a tune with those cams. and get some cam gears.
Old Nov 16, 2007 | 03:26 AM
M2S~Jaime's Avatar
Default Re: P30 pistons in GSR (M2S~Jaime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2S~Jaime &raquo;</TD></TR><TR><TD CLASS="quote">Any rules of thumb out there for P30 pistons in a GSR? Anything like retarding the distributor or adding more fuel and stuff like that?
Thanks in advance. </TD></TR></TABLE>
Anything else out there guys?
How 'bout octane booster, necessary since will be bumping up compression?
Old Nov 16, 2007 | 03:51 AM
M2S~Jaime's Avatar
Ok what about spark plugs? What do I use?
Old Nov 16, 2007 | 07:34 AM
Natural Aspirations's Avatar
Your asking a lot of questions that can be answered with a little searching on your part.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2S~Jaime &raquo;</TD></TR><TR><TD CLASS="quote">Ok what about spark plugs? What do I use?</TD></TR></TABLE>
Same plug you always run 1 step colder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2S~Jaime &raquo;</TD></TR><TR><TD CLASS="quote">How 'bout octane booster</TD></TR></TABLE>
What is your gas octane level in your area? Either way booster is a band-aid fix, tuning is key.
My suggestion to you is to buy a Innovate wide-band, build a DET-Can and teach yourself how to street tune. Tune your friends cars, make some money and buy a dyno.... If there isn't one and racing is popular it will pay for itself/
If you do not understand what I am talking about please take some time and read, search.
Try the big red SEARCH button on the top of Honda-Tech, PGMFI.ORG, Wikopedia and How Stuff Works.
END OF THREAD/
Old Nov 18, 2007 | 07:02 PM
ph3ar's Avatar
Well to add to this, I have a question that I cant find an answer for, and I didnt want to make a whole new thread. I have a b18a1 on the way to me, bored .10 over, and its currently sporting the gsr pistons on the stock rods. I was wanting to get more compression out of it, and was wondering if p30 pistons would fit on the stock rods? Or if id have to modify them or anything else to make them fit. TIA.
Old Nov 18, 2007 | 07:06 PM
Runnerdown's Avatar
Default Re: P30 pistons in GSR (ph3ar)
yes, p30 pistons will go right on stock PR4 B18A rods.
Old Apr 27, 2008 | 08:30 PM
M2S~Jaime's Avatar
Motor rebuilt with the P30 pistons. Feels weak, checked plugs (BKR6) to find that they are white. Lean? Ignition timing set at 0. Only CEL flashing is code 67 because of my popped cat.
Any ideas?
Old Apr 27, 2008 | 11:26 PM
all-mtr-teg's Avatar
You should be running a BKR7 one step colder than stock GSR, used in Type R's. What ecu(tune) are you using?
Old Apr 28, 2008 | 09:11 AM
M2S~Jaime's Avatar
Ok, I'll pick up the BKR7's in the morning. Could that be it though?
Still using the stock GSR box. Later the best I could do as for a tune is match a chipped P28 to my parts and specs.
Old Apr 28, 2008 | 10:02 AM
Stock ecu w/ modded car = lean conditions. You should have gotten at the very least a type r ecu since your using a S2 IM and larger TB, also your CR is much higher than stock so why would you use a stock GSR ECU made for 10:1 CR and secondary butterflies?
Old Apr 28, 2008 | 03:31 PM
M2S~Jaime's Avatar
Actually the only changes on the car right now are the P30's. The manifold, tb, and Toda A2's are still here sitting here in my room. Wanted to see how well it ran with just the piston upgrade. Bad move?
Could the BKR7's still help? NAPA just opened 30 mins ago. Gonna go and grab a set right now.
Old Apr 28, 2008 | 04:35 PM
It'll help to run a colder plug, you may want to retart the timing a degree if your motor's pinging. What octane do you have available there?
Old Apr 28, 2008 | 04:44 PM
M2S~Jaime's Avatar
Old Apr 29, 2008 | 03:00 PM
M2S~Jaime's Avatar
Ok why are the spark plug gaps between the GSR (.052) and Type R (.044) different? Which one should I follow since using P30's or does it matter?
Old May 7, 2008 | 02:22 PM
M2S~Jaime's Avatar
Could I stoich out my leaning problem with a VAFC?
Changed out to colder plugs and still running lean. Is the ecu the only one to blame for this now? Could it be the small stuff like the fuel filter or something?
Old May 7, 2008 | 02:44 PM
Casey's Avatar
prob feels weak bc you have timing at 0...
you can only add so much with a vafc...and youd need a wideband to know where to add
Old May 7, 2008 | 06:19 PM
Rukusmasta2's Avatar
Default Re: (Casey)
running p30s in my GSR
Old May 10, 2008 | 12:39 AM
M2S~Jaime's Avatar
Default Re: (Rukusmasta2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rukusmasta2 &raquo;</TD></TR><TR><TD CLASS="quote">running p30s in my GSR </TD></TR></TABLE>
Any A/F problems?
Old May 12, 2008 | 09:56 AM
BoostKiller's Avatar
when u tune the car retard the timing and run the highest octnae u can ocane boosters are so usless they dont do anything all if pumping 92 octane
LOMPSEG
Apr 3, 2009 05:48 PM
akmi_1
Northern California (Sales)
Oct 10, 2008 05:59 PM
Htounndea
30
Feb 3, 2007 03:31 PM
usdmblackcivic
Jun 19, 2006 06:51 PM
R you serious
May 14, 2003 03:51 PM
