Should I Look for a new Tranny?
Old Nov 15, 2007 | 12:23 PM
NegativeXero's Avatar
Default Should I Look for a new Tranny?
Ok so right before I pulled my engine (B16A w/B16A2 hydro tranny) I noticed that while the clutch was out I would hear a "tap tap tap tap" like something rattling back and forth in my tranny while the clutch was NOT engaged. Once I pressed the clutch pedal in the noise would go away, but as time went on the tranny started to get harder to shift and wanted to pop out of gear, I was thinking It was a bad clutch, but is this a tranny problem?
I need to know if I should get a new tranny before I drop my new setup in, because I don't feel like pulling a tranny 3 weeks after I put my brand new motor in :roll:
Old Nov 15, 2007 | 12:25 PM
sleeperrex's Avatar
Default Re: Should I Look for a new Tranny? (NegativeXero)
bad isb maybe?
Old Nov 15, 2007 | 12:27 PM
dannis.'s Avatar
or throw out bearing maybe??
Old Nov 15, 2007 | 12:29 PM
Default Re: Should I Look for a new Tranny? (dannis.)
But wouldn't it make noise while the clutch was in if it was the TOB?
Old Nov 15, 2007 | 12:30 PM
96electronH's Avatar
sound like tob to me....
Old Nov 15, 2007 | 12:32 PM
Default Re: (96electronH)
Ok if it's a TOB then it's no prob because i've got a brand new clutch and TOB and pilot bearing ready to go in. Just making sure that it's not ISB before i throw the whole thing back in.
Old Nov 15, 2007 | 12:33 PM
Bejita's Avatar
Dude......You have the engine out. Pop the friggin' tranny off and see for yourself instead of guessing over the internet.
Old Nov 15, 2007 | 12:35 PM
Default Re: (Bejita)
Clutch is off already, new clutch/flywheel assembly is ready to go on, how would i know if it had a bad ISB?
Old Nov 15, 2007 | 12:39 PM
King V's Avatar
Default Re: (NegativeXero)
It's the ISB, or at least inside the trans. the noise goes away when you step on the clutch. If it was the TOB, you would have noise while off the clutch. I'd replace all the bearings while its out.
slammed4dreg
Feb 9, 2008 02:39 AM
13link EG
Jul 30, 2005 08:53 PM
AzntaggeR
Mar 13, 2003 03:18 AM
ILOVEGIRLS
Feb 25, 2002 04:10 PM
