D15b2 crx obd-0 in 93 bubble?
Old Nov 15, 2007 | 11:49 AM
90crxdxb16's Avatar
Default D15b2 crx obd-0 in 93 bubble?
is it even possible to put a stock d15b2 90 crx dx modle engine into a 93 civic bubble car despite the obd computer issues? i tried searching i suck at it couldn't find what i wanted.. i was wondering if it is possible to put this engine in this car just cause ihave a good engine and a guy i know needs one for his bubble and i could sell him it cheap..
Old Nov 15, 2007 | 02:25 PM
CapnKrunch's Avatar
Default Re: D15b2 crx obd-0 in 93 bubble? (90crxdxb16)
hahaha yeah it will fit into the "bubble."
Old Nov 15, 2007 | 02:36 PM
Bejita's Avatar
Yes you can....but you need to buy and obd1 to obd0 conversion harness.
Old Nov 15, 2007 | 06:04 PM
4thgenhtch's Avatar
Default Re: (Bejita)
Yes its completly possible and dont even think of converting it to obd0!
Run a p06 ecu, dist, manifold, and injectors, keep the car obd1
It will run fine
Old Nov 16, 2007 | 02:58 AM
90crxdxb16's Avatar
Default Re: (4thgenhtch)
ok cool so i should basically just get a obd1 mpfi manifold and scrap the dpfi garbage and use obd1 d series distrib with ecu? will i have to get another engine harness or will the obd-0 stock harness work im guess i will have to atleast make some modifications to accommodate the injectors along with an injector resistor bx which i have about 3 laying around along with a cut up b series harness would the injectors clips form the b series ls harness work? also what about mountings and shift linkages will the stock mounts work or will i have to get some from a junkyard? i have the crx linkage( basically a front clip) and my last concearn is do i switch the car to cable clutch or the tranny to hydraulic?
Onefry
Sep 30, 2012 07:21 PM
mengy007
Oct 28, 2004 05:38 AM
CRX_GUY_123
22
Jun 8, 2004 10:57 AM
lococoin
May 21, 2004 03:42 AM
TurboSiCoupe
10
Feb 1, 2003 07:10 PM
