Suspension & Brakes Theory, alignment, spring rates....
Increasing ride height w/ spacers or washers?
Old Nov 15, 2007 | 11:19 AM
eggie75's Avatar
Default Increasing ride height w/ spacers or washers?
hey,
Back when I first got my lude, I dropped it down 1.8". Now after XX sets of tires, I was thinking of raising it a lil. I have H&R's w/ KYC g2's. I was thinking of just putting in like some 3/8" spacers between the top plate and the chasis. Any thoughts on this?
Old Nov 15, 2007 | 11:30 AM
.:Made in OC:.'s Avatar
Default Re: Increasing ride height w/ spacers or washers? (eggie75)
And... what are the spacers supposed to do? Are you not getting enough rebound? If not, then your too low... raise your car up and save yourself tires and increase handling characteristics.
Old Nov 15, 2007 | 11:50 AM
eggie75's Avatar
ride is fine. just trying to raise it up a bit without changin the whole setup.
Old Nov 15, 2007 | 02:06 PM
verycleanhatch's Avatar
are you getting alot of tire wear? if so just get a camber kit.
Old Nov 15, 2007 | 02:55 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eggie75 &raquo;</TD></TR><TR><TD CLASS="quote">hey,
Back when I first got my lude, I dropped it down 1.8". Now after XX sets of tires, I was thinking of raising it a lil. I have H&R's w/ KYC g2's. I was thinking of just putting in like some 3/8" spacers between the top plate and the chasis. Any thoughts on this?</TD></TR></TABLE>
My thoughts:
Did you ever have the car aligned after you changed the ride height?
Because if you didn't, then you're addressing the problem from the wrong angle (alignment tech joke, ha ha).
Get the car on an alignment rack (with fresh tires - unevenly worn tires won't allow it to line up properly) and have them set the toe to dead center of the factory specs. That should solve the majority if not all of your tire wear issues, without buying additional parts and/or screwing around with unsafe setups. And it's something you should have already done to begin with.
Old Nov 16, 2007 | 01:01 PM
eggie75's Avatar
yea, tire wear is the main issue.
toe is aligned.
only ball joint camber kits are available for 5th gen ludes. I bought one before, but if you compare vs stock, they are taller on the top of the lca. my ball joints already hit so a camber kit would've probably punched through so i sold em.
Old Nov 16, 2007 | 02:04 PM
Tyson's Avatar
Default Re: (eggie75)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eggie75 &raquo;</TD></TR><TR><TD CLASS="quote">yea, tire wear is the main issue.
toe is aligned. </TD></TR></TABLE>
are you wearing unevenly? whats your alignment specs? when was the last alignment?
Modified by Tyson at 4:32 PM 11/16/2007
Old Nov 16, 2007 | 03:22 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eggie75 &raquo;</TD></TR><TR><TD CLASS="quote">yea, tire wear is the main issue.</TD></TR></TABLE>
How are they wearing? Pictures and tread depth measurements help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">toe is aligned.</TD></TR></TABLE>
Post the spec sheet.
RedlineNeutralDrop
Apr 14, 2007 04:07 PM
Tealeg88
17
Dec 28, 2005 04:27 AM
Thirty-Nine
Nov 28, 2005 05:52 PM
ceboyd
17
May 19, 2004 02:35 PM
Cowtit
Aug 29, 2003 04:45 PM
