Anyone use a transmission cooler? (auto slushboxes)
Old Nov 15, 2007 | 10:09 AM
.Ash's Avatar
Default Anyone use a transmission cooler? (auto slushboxes)
I was curious if anyone uses transmission coolers for their auto transmissions. The reason I ask is because every civic I see with a blown H/G is usually an automatic transmission. Is it possible that the tranny fluid that runs thru the radiator heats up to a temp where it causes the coolant that runs thru the radiator to heat up to the point of blowing a headgasket? My car in question is a 1992 DX Hatchback if it matters. Thanks!
Old Nov 15, 2007 | 05:18 PM
ejoner's Avatar
Default Re: Anyone use a transmission cooler? (.Ash)
No unless your retarded and don't pay attention to the gauges in front of you, its has a area marked in red for a reason. Yeah having the transmission fluid run threw the radiator probably makes everything a little hotter not that it isn't already but thats what the fan is for and cold air hitting your radiator. Almost all stock auto cars use the radiator to cool the transmission fluid also and you don't think they would have changed the design of the tranny cooler in the radiator? "because every civic I see with a blown H/G is usually an automatic transmission." How many have you seen? -Ejoner
Old Nov 15, 2007 | 06:03 PM
d357r0y's Avatar
It's not a Civic but I just put a tranny cooler on my '00 Odyssey van and it's working great.
Honda auto trannies kinda suck in design, no replaceable filter, gotta drain it 3 times to get all the old fluid out.
You could install a cheap one for less than $50 and it's super easy.
Old Nov 16, 2007 | 12:46 AM
.Ash's Avatar
Default Re: Anyone use a transmission cooler? (ejoner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejoner &raquo;</TD></TR><TR><TD CLASS="quote">No unless your retarded and don't pay attention to the gauges in front of you, its has a area marked in red for a reason. Yeah having the transmission fluid run threw the radiator probably makes everything a little hotter not that it isn't already but thats what the fan is for and cold air hitting your radiator. Almost all stock auto cars use the radiator to cool the transmission fluid also and you don't think they would have changed the design of the tranny cooler in the radiator? "because every civic I see with a blown H/G is usually an automatic transmission." How many have you seen? -Ejoner</TD></TR></TABLE>
They pop up on Craigslist now and then, always an auto trans.
gold_pwr_r4ng3r
Honda Civic (2001 - 2005)
Apr 10, 2012 11:32 AM
RA61825
Sep 19, 2009 04:45 AM
z6hatchboy
Dec 21, 2007 09:14 PM
6shootahorsenamedtrigga
Jun 1, 2007 04:09 PM
lilxvtecxpwr
Sep 19, 2002 01:52 AM
