What is an Intake Cam, and what does it do???
Old Nov 15, 2007 | 09:53 AM
Razr2's Avatar
Default What is an Intake Cam, and what does it do???
I have a 2000 Civic si, and I just found out that it has a CTR intake cam. I know what cams are but is a Intake cam different? What does it do? How does it work?
Does the CTR cam increase power over the stock b16 intake cam?
Thanks.
Old Nov 15, 2007 | 10:03 AM
Eran's Avatar
HT White Ops
An intake cam is just as it sounds -- a camshaft that controls the intake valve.
DOHC motors have one cam for the intake valves and one cam for the exhaust valves. In a SOHC system, the cam controls both sets of valves.
This is the sought-after advantage with DOHC over SOHC. The intake and exhaust can be tuned separately.
As for a CTR being better, yes, it does have a more aggressive profile and nets some gains (not much) over the stock cams. It is a rather popular setup for budget turbo projects, putting either the CTR/ITR intake cam into a B16/B18C motor.
Old Nov 15, 2007 | 10:33 AM
Razr2's Avatar
Default Re: (Eran)
Oh okay thanks. So is it common for someone to just change out the intake cam and not the exhaust cam?
Old Nov 15, 2007 | 10:44 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: (Razr2)
More common for a CTR intake/GSR exhaust setup. Although it has been done.
Old Nov 15, 2007 | 12:09 PM
Razr2's Avatar
Default Re: (black_EM1)
I just found out that it has the CTR intake cam and stock si exhaust cam but it's not tuned. How much power do you usually gain from this?
Old Nov 15, 2007 | 12:12 PM
black_EM1's Avatar
Community Builder
Default Re: (Razr2)
I couldn't tell you off the top of my head, I'd have to look for it. Actually have you tried searching?
Look in the archives. There's some good information in there.
Old Nov 15, 2007 | 12:13 PM
Bejita's Avatar
Probably less than 5hp.
EDLOVA23
Oct 10, 2008 02:53 PM
redDAinteg
Apr 25, 2007 09:10 AM
92 civic VX B18c
Sep 15, 2003 06:16 AM
Vtec-Jesus
May 11, 2003 03:06 PM
SwitchCabNine
May 1, 2003 08:10 AM
