Vtec Solenoid question
Old Nov 15, 2007 | 05:38 AM
iblewmyrmotor's Avatar
Default Vtec Solenoid question
Are B & D series Vtec solenoids interchangeable?
When I searched I came across this. https://honda-tech.com/zerothread?id=2109107
There's not a solid answer
Modified by iblewmyrmotor at 9:50 AM 11/15/2007
Old Nov 15, 2007 | 06:20 AM
B16B_coupe's Avatar
HRD PKR
Default Re: Vtec Solenoid question (iblewmyrmotor)
2000 civic ex: vtec spool valve.15810-P2R-A01
2000 civic si : vtec solenoid.36171-P08-005
you cant get the vtec solenoid seperate on the d series like the b series.. but from the looks of it. the top 3 bolts will line up... the spool valve's are different
Old Nov 15, 2007 | 06:52 AM
Default Re: Vtec Solenoid question (B16B_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe &raquo;</TD></TR><TR><TD CLASS="quote">2000 civic ex: vtec spool valve.15810-P2R-A01
I got a D series solenoid, and trying to see if'll work on my GSR head.
Old Nov 15, 2007 | 08:03 AM
B16B_coupe's Avatar
HRD PKR
well if it will bolt up it should work
Old Nov 15, 2007 | 08:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe &raquo;</TD></TR><TR><TD CLASS="quote">well if it will bolt up it should work</TD></TR></TABLE>
Thanks!
Jap_Spec_Imports
Apr 7, 2008 08:27 AM
Jap_Spec_Imports
Apr 6, 2008 01:06 PM
crazyjetsfan22
Dec 6, 2006 12:29 AM
