lug nuts?
Old Nov 15, 2007 | 05:06 AM
marecco's Avatar
Default lug nuts?
so im going to be throwing a set of steelies on for the winter time and i have extended studs with skunk2 lugs. just wondering if i can use my lugs with steelies?
Old Nov 15, 2007 | 05:34 AM
Doostur's Avatar
Default Re: lug nuts? (marecco)
The extended studs dont matter. It may not look pretty but it wont effect your stock wheel being put on. As for your lugnuts, any rounded or acorn end lugnut would work although the best and safest would be "ball/radius/spherical shaped seating area"
Read the FAQ for additional info.
Old Nov 15, 2007 | 10:34 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: lug nuts? (Doostur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marecco &raquo;</TD></TR><TR><TD CLASS="quote">so im going to be throwing a set of steelies on for the winter time and i have extended studs with skunk2 lugs. just wondering if i can use my lugs with steelies? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doostur &raquo;</TD></TR><TR><TD CLASS="quote">The extended studs dont matter. It may not look pretty but it wont effect your stock wheel being put on. As for your lugnuts, any rounded or acorn end lugnut would work although the best and safest would be "ball/radius/spherical shaped seating area"
Read the FAQ for additional info.</TD></TR></TABLE>
You (Doostur) are assuming that his steelies have a ball-shaped seating area. I don't know if that's always the case with steelies the way it is for almost all Honda/Acura brand wheels.
In any case, you need to get lug nuts whose seating area is the same shape as the seating area of the wheels, as described in the FAQ topic stickied at the top of this forum. Sometimes it's easier to discern the shape by feeling it with your fingertip rather than eyeballing it. If you need open-end lug nuts with a ball-shaped seating area, the FAQ topic tells where to get them.
Old Nov 15, 2007 | 11:43 AM
.:Made in OC:.'s Avatar
hope you dont get confused by the picture op, because those are wheel bolts, not lug nuts. Different things.
Old Nov 15, 2007 | 03:36 PM
marecco's Avatar
yeah well when i sold my wheels i sold the lugs with them anyway so its a mute point now lol..
Old Nov 15, 2007 | 05:50 PM
Doostur's Avatar
nsxtasy, you got me
Old Nov 15, 2007 | 05:59 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: lug nuts? (.:Made in OC:.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .:Made in OC:. &raquo;</TD></TR><TR><TD CLASS="quote">hope you dont get confused by the picture op, because those are wheel bolts, not lug nuts. Different things.</TD></TR></TABLE>
True - but the idea (of the shapes of the seating area) is the same.
Maybe you like the other diagram in the FAQ better?
BAZ
15
Oct 1, 2006 04:54 PM
dfoxengr
Welding / Fabrication
15
Jul 14, 2005 05:21 AM
jimmhatch
10
May 21, 2005 05:21 PM
mattb16a1civic
May 15, 2005 12:14 PM
BLUE_DC2
Feb 25, 2004 03:11 PM
