Can A GS-R Head Gasket Be Used On A LS
Old Nov 14, 2007 | 11:40 PM
Scorchin Civic's Avatar
Default Can A GS-R Head Gasket Be Used On A LS
Just wanting to see if it's possible to do this. I placed a order for a non v-tec 85mm head gasket and they sent me a GS-R one instead. Or just a plain old v-tec gasket if there is no difference when it comes to v-tec cause I an not 100% sure it's for a GS-R. So can a v-tec head gasket be used with a LS/B20?
Old Nov 15, 2007 | 04:17 AM
B16B_coupe's Avatar
HRD PKR
Default Re: Can A GS-R Head Gasket Be Used On A LS (Scorchin Civic)
call acura and have them check the part numbers, that would be the easy way to do it
Old Nov 15, 2007 | 05:57 AM
It's a Cometic head gasket and I checked it and it's for a b series v-tec motor
Old Nov 15, 2007 | 06:03 AM
B16B_coupe's Avatar
HRD PKR
Default Re: (Scorchin Civic)
b16 12251-P30-014
ls/b20:12251-P8R-004
so it says part number's are different
98 gsr:12251-P30-014
98 ls :12251-P75-004
Old Nov 15, 2007 | 10:15 AM
I know the head gaskets are different from v-tec to non v-tec. I am wanting to know can you use a v-tec head gasket on a non v-tec motor with out having any problems. If I am right the v-tec motors have the extra oil hole in there head gasket. Since the non v-tec motors don't it will just be covered up, right?
1990hf
May 20, 2008 06:56 PM
blk90teg
Feb 14, 2007 08:53 PM
PNG
Sep 14, 2006 05:16 PM
civicswap
Jun 4, 2005 06:44 PM
