308whp k24/k20 swap
Old Nov 14, 2007 | 10:38 PM
Rusty Shackleferd's Avatar
Default 308whp k24/k20 swap
K24A4 block
90mm bore erl sleeved
cp piston
ib I beam rod
stock 99mm stroke crank (spun balanced)
evolution industries 8 lb flywheel
evolution industries balancer pulley
arp head studs
acl race bearings
rings & brearing have about 10 passes on them
K20A2 HEAD
ported and welded chambers
stock intake valve
s2000 exhaust valve
crower springs and ty retainers
IPS K10 cams
skunk 2 adjustable cam gear (intake)
(many hours put into this head as far as port work and valve job)
6 SPD TRANNY
06 type s gears
02/04 4.38 FD
misc parts
custom 4-1 drag header with burns collector and megaphone
custom ron davis small radiator
haltech e8 ecu and motor harness
wide band o2 sensor
4 msd blaster coils & msd wires
innovative motor mounts
rsx axels with mid shaft
660cc injectors
2100 lbs pressure plate with 3 puck disk
includes all sensors, alnator, starter
shifter box and cables
the motor makes 308hp and 211tq on 25" slicks on a 248 dyno jet... This motor went 10.88 in a 2100 pound car with 299whp... we found another 8 hp in the intake ports mid year but didnt get a clean pass to see what it could do...i have over 15K into the motor over the last 2 years...first trip to the dyno it made 268 and after 2 years and hundreds of dyno pulls and trying different things we squeezed 308 out of it....i would tear down the motor after every race to inspect parts...so the motor has been maintained and only has about 10 passes on it since i changed the rod bearings, rings, head gasket and valve job...and one of the those passes was the 308hp dyno pull
i'll sell everything for 8900.00 obo
i am willing to part out if i cant get rid of it complete
Old Nov 14, 2007 | 11:09 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: 308whp k24/k20 swap (Rusty Shackleferd)
POWA!!!!!!!!!
Old Nov 15, 2007 | 08:46 AM
bump
Old Nov 15, 2007 | 08:48 AM
buckNasty's Avatar
nice setup
Old Nov 15, 2007 | 11:59 AM
OUT OF ORDER ROB's Avatar
Default Re: 308whp k24/k20 swap (buckNasty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buckNasty &raquo;</TD></TR><TR><TD CLASS="quote">nice setup</TD></TR></TABLE>
Damn Serious, only if i had money.
Old Nov 15, 2007 | 03:57 PM
JRSC01GS-R's Avatar
Default Re: 308whp k24/k20 swap (OUT OF ORDER ROB)
very nice
Old Nov 15, 2007 | 05:28 PM
michael_c's Avatar
hey i've got an extra kidney...interested?
Old Nov 15, 2007 | 07:44 PM
jdm biker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OUT OF ORDER ROB &raquo;</TD></TR><TR><TD CLASS="quote">
Damn Serious, only if i had money.</TD></TR></TABLE>
me too
Old Nov 17, 2007 | 06:09 PM
sa90eg's Avatar
Default Re: 308whp k24/k20 swap (jdm biker)
would u ever part the motor?
Old Nov 21, 2007 | 02:48 AM
STREETWERKZ's Avatar
Default Re: 308whp k24/k20 swap (sa90eg)
ive seen this bitch run down evvvvvveryone! FAST MOTOR!
Schlitzjr
Jan 11, 2013 04:51 PM
Rusty Shackleferd
Nov 15, 2007 09:18 AM
Rusty Shackleferd
Nov 15, 2007 09:00 AM
racingant
Feb 2, 2006 04:37 PM
